hi guys i have a mk2 turbo rev2 i am buying a ct20b turbo but i have the ct26 fitted at the moment i find i get alot of boost spike (as i am running a bleed valve and droped forged acctuartor) how can i resolve
cheers and a merry christmas chris
Help
Re: Help
mr2chris wrote:hi guys i have a mk2 turbo rev2 i am buying a ct20b turbo but i have the ct26 fitted at the moment i find i get alot of boost spike (as i am running a bleed valve and droped forged acctuartor) how can i resolve
The actuator will need quite a bit of air directed to it to open it, so your bleed valve is effectively bleeding the air away from the feed to the actuator. Keep the feed from the compressor housing to the bleed valve then to the actuator as short as possible. The longer it is, the more spike your going to come across.
Also, what sort of pipe are you using. You realistically need to use the reinforced type, none of this bling blue stuff that expands at the slightest bit of heat.
Ensure all ends are circlipped to the pipes properly.
Ought to do it.... !
Re: Help
cheers mate i havent put circlips on the pipes i am also investing in a electronic boost controller to get in a bit safer
