pop up lights
pop up lights
Pop up headlight on near side wont come. Any suggestions as to how to address this problem?
Re: pop up lights
mccolganm wrote:Pop up headlight on near side wont come. Any suggestions as to how to address this problem?
check the fuse first
Re: pop up lights
switch it to full beam and see if it works if it does work you may have water in your system it some times healp to breifly dry the connector out to get rid of moisture!
