Well I have always had good tyres on my MR2 and any other car for that matter until I got the new wheels. I was fine with them until tonight. They have a set of ditch finders on the rear and I found that it would spin up the rears in 4th gear! They will be swapped for the other wheels in the morning until I decide what tyres I want on them.
Be warned people the difference in the price of the cheap tyres for good ones is well worth it to save your pride and joy!
Sam
Ditch finders!
Re: Ditch finders!
yeah, I've usually put mid range tyres on mine but this time round I might splash out and get some seriously rubber..
Re: Ditch finders!
The 2 MOST important things on a car is Brakes and Tires..
Re: Ditch finders!
Worth bearing in mind that:
- OLD tyres go hard, and lose heaps of grip as a result. Sometimes if they have been unused the surface will recover after a bit of wear.
- NEW tyres will have both mold release agent and the small rubber "hairs", both of these will wear off.
....of course, it's also very true that some tyres are simply s###!
WMS 4 pot brake kits in Affiliates! Mk1: www.imoc.co.uk/forums/viewtopic.php?t=128889 & Mk2: www.imoc.co.uk/forums/viewtopic.php?t=140657
Re: Ditch finders!
Keri-WMS wrote:Worth bearing in mind that:
Yeah that's true. Well I think I'm going to order the new Hankook K120s tomorrow and see how they work out. Fingers crossed.
Re: Ditch finders!
I've had so called ditch finders Nankank NS2 on my MR2 tubby for around 8yrs (not same set lol) and previously on my BMW 325i and never once found the back end stepping out unless i wanted it to.
Yes tyres make a difference and yes toyo proxies might go around a corner faster but if they let go which they do then you are also heading towards that ditch faster.
Re: Ditch finders!
I think though the way in which a tyre loses grip is important. You want a progressive tyre to try open that small margin which catches drivers out all the time when they experience snap oversteer.
Personally I am going for a set of Michelin Pilot Sports or Yokohama AD08R, not because they are expensive just because they have consistent reviews for being very sticky tyres, in dry and more importantly wet conditions
Now I am not saying there arent any quality tyres at a cheaper price Im just personally not willing to test a range of potentially worse tyres.
Black 94' GT-S Turbo
Re: Ditch finders!
when I got the tubby it had Bridgestone S02's on it and dear god they were brilliant tyres (15's too). Then after they were taken off the market Eagles f1's, D2's then 17's to get Eagles but they were D3's so not so grippy (had Yoko's in 15's, ok) Then Kumho's but I reckon yeah Pilot Sports or the AD08's just for outright grip..... damn that snow up here!
Might get a set of winter wheels and fit skinny tyres on them... if they clear the BBK....
Re: Ditch finders!
raptor95GTS wrote:had Bridgestone S02's on it and dear god they were brilliant tyres (15's too).
Yep - miss them - they were excellent.
Falkens aren't bad, 452s are phased out but the 453s also look pretty good.
Re: Ditch finders!
yea it's falken 453's I have at the mo on the rears and while they are ok, they aint great but then it is a mid range tyre so it does behave like one
Re: Ditch finders!
samgpr50 wrote:I found that it would spin up the rears in 4th gear!
Sam
What make are they?
I want some, it sounds like they go a long way to reducing understeer.
Re: Ditch finders!
aw11rally wrote:samgpr50 wrote:I found that it would spin up the rears in 4th gear!
Sam
What make are they?
Think they were fortuna. Not too sure though as they have now gone.
Re: Ditch finders!
gavsdavs wrote:raptor95GTS wrote:had Bridgestone S02's on it and dear god they were brilliant tyres (15's too).
SO2 N3's are now being listed in 255x40x17................ in stock too with a few places... tempted but then what to get to match the fronts to them...
Re: Ditch finders!
got a set of ditch finders on mine at mo, Mohawks I think, everytime I come to a roundabout in the wet I can feel them sliding across the road no matter what speed lol understeer
got rainsport 2 on the rear which have yet to scare me
Re: Ditch finders!
samgpr50 wrote:Keri-WMS wrote:....of course, it's also very true that some tyres are simply s###!
I know several people who have the K110s and rate them. If the 120s are as good or better then you should be OK.
raptor95GTS wrote:when I got the tubby it had Bridgestone S02's on it and dear god they were brilliant tyres (15's too). Then after they were taken off the market Eagles f1's, D2's then 17's to get Eagles but they were D3's so not so grippy (had Yoko's in 15's, ok) Then Kumho's but I reckon yeah Pilot Sports or the AD08's just for outright grip..... damn that snow up here!
The only reason I use GS-D3s on the front is they don't do the Assymetric 2s in the required width.
Outright grip is secondary. It's all about feedback - knowing what the tyre is going to do. Also in the UK, with its changeable weather, the key thing to concentrate on is performance in the wet. Pilot Sports and AD08s are summer tyres - next to useless in snow. Furthermore no summer tyre of any make will perform that well in ambient temperatures below 7 degrees Celsius.
http://www.tyresforlife.co.uk/www/tyres ... on-en.html
Re: Ditch finders!
red, agree with what you said. Feel is as important as outright grip, I just want a tyre that'll grip more than I'll likely use under normal circumstances and have enough grip for those OMG situations. Feel, yeah thats exactly why I dont buy Toyo tyres, jelly mould sidewalls. AD08's are rated to -7 I'm sure but aye not recommended for snow . If I could I'd have summer and winter wheels but I can't so it is what it is
Re: Ditch finders!
I have the AD08s on the RX7 at the moment and they are superb.
When they're cold in the morning though - they are deadly.
It spins the wheels, like im driving on an oil slick every morning for the first couple of miles, then when they warm up...... they are a joy to drive on. Once warm - I have never made them let go.
They do wear damn quick though, 2000 miles for the rears I reckon.
Re: Ditch finders!
hmltnangel wrote:I have the AD08s on the RX7 at the moment and they are superb.
I thought you were on A048s. Having seen your car and heard you describe it, I didn't realise the AD08s were so road un-friendly
Almost bought a set too, glad I didn't.
Re: Ditch finders!
Hmmmm, was I just rambling in a moment of confusion? You are right mate, it's AO48s that I have.
Oops.
Oops.
Re: Ditch finders!
Different kettle of fish!
Bet they aren't good for -8!
