Not yet.
Been toying with the idea,checking up on iffy things to look out for, like these precats things that look like they can cause trouble.
Also the misses has had a go at me about the amount of junk
(as she calls it) that has to make way
(semi deceased Talbot 1986 camper and mk2 turbo) before I can get another vehicle on the drive.
May see if its still for sale in a few days, its hard as can't afford the mk2 as well as the mk3 so will have to sell the mk2 and even though it is pretty scary at high speeds and showing rust on the door it is still incredibly reliable and one part of the brain says better the devil you know, while the other says get something a little more modern and finalize you twoing by having a mk3 and get back to enjoying cornering like you did in the mk1.
It really is a tricky one
