Hi guys,
My speedometer is almost perfect, except for the fact that it'll sometimes jump up a few MPH. I'll be cruising at say 40, then every few minutes or so, without accelerating, it'll jump to 60+ and fall straight back down to 40 again. It's a Rev 3 turbo (originally NA, swapped to a rev 3 turbo engine 10 years or so ago).
Ideas? It's hardly the end of the world, but still a PITA
I can get a video up at some point if necessary.
[Mk2] [Turbo] Bouncing speedometer
Re: [Mk2] [Turbo] Bouncing speedometer
As it's converted, could you look at the gearbox and see if it's a cable or digital speed sensor?
What year is the chassis?
Chassis is 1995, rev 3 turbo engine so it must be of similar times. Although at this point I'm unsure if it has a turbo or NA gearbox
Check theres no water in the gearbox sender plug/socket and that cables are I good repair.
