[Mk2] [Generic] o.e. sub - anyone done a direct replacement
Just wondering if anyone has done an upgrade in the standard box?
Re: [Mk2] [Generic] o.e. sub - anyone done a direct replacement
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
or this direct replacement:
![Image](https://dl.dropboxusercontent.com/u/41644014/Turbo/new%20sub%20enc.jpg)
I lined the stock enclosure inside and out with Vibe sound deadening material to try to lower the resonant frequency of the plastic enclosure, and then fitted a Vibe Slick 5 speaker.![](./images/smilies/spacer.gif)
Paul
Paul
madbasshunter wrote:Like this
[url]http://i536.photobucket.com/albums/ff327/madbasshunter/Purple%20Haze%20MR2/2013-06-28150906_zpsd6b611f4.jpg
[/URL]
5.25" woofer with mdf adapter
[url]http://i536.photobucket.com/albums/ff327/madbasshunter/MR2%20Install/2013-06-09155127_zps6b8641e0.jpg
[/URL]
yep.
and are you both running off o.e.
amp, or an aftermarket?
I've fitted a small Kenwood sub amp in the frunk connected to the line level sub output on my head unit.![](./images/smilies/spacer.gif)
![Image](https://dl.dropboxusercontent.com/u/41644014/Turbo/Frunk%20Aug%2015.jpg)
This enables me to roll off higher frequencies to try to get the best out of what is quite a small sub unit without having to drive it too hard.![](./images/smilies/spacer.gif)
It looks like madbasshunter is using a
PYLE PLG54 in his oem sub enclosure.![](./images/smilies/spacer.gif)
Paul
Paul
Yes it is a Pyle PLG54 Paul
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/MR2%20Install/2013-06-09155317_zps2fd1842c.jpg)
I ran it off the factory amp
(so at half power as 4ohm load not 2ohm), it was only run for a few minutes as a trial before I put this in
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/My%20MR2%20Install/2014-09-15181224_zps21c75ac0.jpg)
as I like more bass than a 5.25 can manage![](./images/smilies/spacer.gif)
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/My%20MR2%20Install/2015-07-17%2018.34.14_zpsse344sjx.jpg)
The amps are in the boot
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/My%20MR2%20Install/2015-07-19%2016.10.29_zpstyflhm1a.jpg)
but are removed at the minute as I have a bigger amp going in for the sub 1000w rms at 1 ohm instead of the 500w rms one
Got one of those pyle subs, but not good running it on o.e.
amp
Would an aftermarket amp fit under a seat does anyone know?
madbasshunter wrote:Yes it is a Pyle PLG54 Paul
I ran it off the factory amp(so at half power as 4ohm load not 2ohm), it was only run for a few minutes as a trial before I put this in
Mega stuff mbh
![Smile :)](./images/smilies/icon_smile.gif)
acf8181 wrote:Got one of those pyle subs, but not good running it on o.e.amp
I think you's struggle to find an amp thin enough to fit under the seats, there's really not much height there.
Most people seem to fit amps on the rear firewall in the cabin or in the frunk.
Paul
Pauln wrote:acf8181 wrote:Got one of those pyle subs, but not good running it on o.e.amp
I think you's struggle to find an amp thin enough to fit under the seats, there's really not much height there.Plus it's always a good idea to make sure air can pass around the amp.
Paul
I fitted an amp
Be creative mate
So there's plenty of room then 2mad?!
Won't be anything like as adventurous for me, smaller the better!
![Shocked :shock:](./images/smilies/icon_eek.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
acf8181 wrote:So there's plenty of room then 2mad?!![]()
Mine fitted
![Sad :(](./images/smilies/icon_sad.gif)
My amps were pretty big and they went under the seats ok
Just goes to show how wrong you can be
I had originally hoped to fit my small Kenwood sub amp under the seat, but just couldn't make it fit without jamming when the seat slid backwards.
I should have bought a Vibe, and saved myself a lot of work.
Paul
Paul
Pauln wrote:Just goes to show how wrong you can be![]()
I had originally hoped to fit my small Kenwood sub amp under the seat, but just couldn't make it fit without jamming when the seat slid backwards.I should have bought a Vibe, and saved myself a lot of work.
Paul
Not sure if that was sarcasm Paul
![Anxious 8-[](./images/smilies/eusa_shifty.gif)
No it wasn't sarcasm, not my style.
I bought a Kenwood amp in he hope that I could fit it under the seat, but no matter how much I fiddled with it I couldn't make it work.
So ended up having to make a suitable panel and fit it in the frunk, which with my very basic woodworking skills took a lot more time to sort.![](./images/smilies/spacer.gif)
Sorry if I came across badly, I didn't mean to.![](./images/smilies/spacer.gif)
Paul
Paul
Pauln wrote:No it wasn't sarcasm, not my style.![]()
I bought a Kenwood amp in he hope that I could fit it under the seat, but no matter how much I fiddled with it I couldn't make it work.So ended up having to make a suitable panel and fit it in the frunk, which with my very basic woodworking skills took a lot more time to sort.
Paul
Aw my bad sorry mate
![Embarassed :oops:](./images/smilies/icon_redface.gif)
I fitted a turbo alternator and added 0gauge wiring to it 2Mad
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/My%20MR2%20Install/Alternator%20Big3_zps03d02nor.jpg)
Have always found under the seat very shallow on the mr2, I did try fitting a vibe optima underseat sub![](./images/smilies/spacer.gif)
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/Parts%20For%20Sale/2013-12-14131015_zps2c454e88.jpg)
but it lifted the seat so it couldn't be bolted down![](./images/smilies/spacer.gif)
![Image](http://i536.photobucket.com/albums/ff327/madbasshunter/Parts%20For%20Sale/2013-12-14130614_zps71eee8de.jpg)
0gauge wiring ftw mbh
nice
![Very Happy :D](./images/smilies/icon_biggrin.gif)
