jimGTS wrote:as mentioned in your other post, cool vid, i would be a little more consistent on your hand position, it does tend to move around wheel which is what i read to avoid.
and maybe its just me but you hold it quite high.
Indeed, I'd be inclined to agree.
You're nice and smooth already, and you certainly seem to be driving well within yourself and the
(super-quick) car.
However,
(and this also goes for jimGTS), you need to be sitting closer to the steering wheel and/or more upright.
Your arms should be bent roughly to 90deg at the elbows when sitting upright with your hands at 3 and 9.
If not, you end up stretching to reach the top of the wheel
(as in both videos), meaning slightly less control when you need to move it quickly.
Heel and toe makes hard braking easier, and ultimately makes you quicker into and through the corners.
It's really hard at first, because it's such an illogical thing to be doing
- but persistence is worth it.
