TOO NOISY?
TOO NOISY?
Hi, I have a rev 2 Turbo with a blitz nur spec r exhaust fitted, does anyone know if this is too loud for Castle Combe? (98dB), I'm hoping it will be OK. I have the baffle that slides into the 'silencer' which does make it quieter but ideally dont want to have to fit it in the track.[/b]
- Lauren
- Premium Member
Re: TOO NOISY?
If you think your exhaust is loud it will likely fail the noise test at combe. If you are reasonably near, give them a ring and pop down and they will check it for you.
needs to be 98db or lower at 3/4 revs 0.5m @45deg angle from exhaust. you may be able to hire a noise meter from your local hire shop.
Re: TOO NOISY?
aren't they a bit nazi at Combe with regards to noise? (due to local residents)
- Lauren
- Premium Member
Re: TOO NOISY?
nikaso wrote:aren't they a bit nazi at Combe with regards to noise? (due to local residents)
They are nazi pretty much everywhere these days. Donny are stricter i think.
