Hi all
After some advice, probably a stupid question however I am doing my first build on a rev 2 3sgte engine all standard just a hobbie really i have followed all the guides etc however when i turn the crank pully with a socket i noticed the force required is not constant it seems to ease off in places is this normal?
Engine turn over.
Re: Engine turn over.
Yes, if you have the spark plugs in.
It will be one of the pistons on its compression stroke causing the resistance.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Ah thanks for the feedback muck appreciated.
I am also hearing air escaping from the flywheel side but that could be anything as their is still plenty to attach yet.
[/img]
[/img]
- IMOC Moderator
If the engine is operating as normal then yes, This is normal behaviour. Remember the valves are opening and closing as you turn the crank.
