3SGTE engine rebuild - recommended workshops
Looking for recommendations on a workshop that can remove / rebuild / install a 3SGTE, suspect bottom end failure. Rebuild would be to OEM spec but with forged pistons, nothing crazy. Closer to London / Essex would be preferable, but I will travel for the right service.
Re: 3SGTE engine rebuild - recommended workshops
Drift limits performance did my build, although it wasn't a failure it did need machining etc.
What happened? it was running allright not that long ago?
Race Idiot wrote:Drift limits performance did my build, although it wasn't a failure it did need machining etc.
Ran out of oil.
I'm sure we talked about it briefly... It has always used a bit of oil and I suspect it has a worn out cyl 3 oil control ring or broken ringland as cyl3 spark plug was dirtier than the rest (to the point of misfire), compression was still 160-170 across the board though. I just checked and topped up every week and thats managed it OK.
Took it out on Saturday, all good (had last checked oil during the week, small top up to full). Started it on Sunday, drove barely a 1/2 a mile down the road and a noise developed. Checked oil, it was a couple mm below minimum. Need to drop the oil this weekend and have a good look / check it all over, but seeing as it was low and there's now a knocking noise, its probably bottom end. Walks like a duck, quacks like a duck...
I've emailed them anyway, see what they're saying. There's possible options for sending the engine away and DIY install, but the logistics are tricky as I don't have my own space for this, and at least if a shop supplies and fits everything if it goes boobs up shortly after it can go straight back and there's no room for any bull$h1t either side for install error / wrong oil / other stuff.
I guess leakdown test is in order. I mean it could just be a very rattly heatshield right???
I'd give driftlimits a call instead of e-mailing, if you get hold of Lilly she can talk you through costs for a build or at least get back to you with them.
Would have to be a very big and heavy heatshield to make that noise... Will go through it on the weekend. Can't drive it anywhere as is with the noise its making so will check all the external bits like pulleys / belts, then drop the oil and see what its saying. I'm expecting bits though honestly.
Id recommend predator performance or for a bit more money Rogue.
Predator done the initial rebuild although i had a few problems the engine ran brilliant before i totalled the car.
Rogue also know their stuff if you want a no hassle remedy. The problem being you pay for that sort of service.
I'd be pulling the sump off and checking the bearings before I committed to a full engine out rebuild. You might be able to just replace a couple of main or big end bearings in situ.
luke2152 wrote:I'd be pulling the sump off and checking the bearings before I committed to a full engine out rebuild. You might be able to just replace a couple of main or big end bearings in situ.
Cyl3 is suspect anyway, seems counter intuitive to take the shortcut route when I know cyl3 has an oil issue.
done a compression test?
I've not touched it yet, but I'm not asking for technical advice here.
I've used Martin Kingston and can't complain about the work or price.
https://www.mkautorepairsandtuning.uk/
SonicSW20 wrote:luke2152 wrote:I'd be pulling the sump off and checking the bearings before I committed to a full engine out rebuild. You might be able to just replace a couple of main or big end bearings in situ.
I've got a full set of good used bearings you can have. Doesn't sound like want to take shortcuts but could be worth a shot for free.
You're not far from these guys. They built my forged 3sgte motor, and it's been faultless. http://www.scholarengines.co.uk/
