Sadly the time has come to part with my beauty, I can't justify keeping her anymore and pulled the plug on selling earlier in the year only to do a full circle.
I've had no close offers to what I had advertised her for so this is the end result, rest assured every part will live on including the shell/plates/history.
ENGINE/RUNNING GEAR
* Fully built drag spec engine (worked on/built by Rogue Motorsport/Tony Gibbons) built for 2.5bar+, Rev 5 block with custom oil and water lines, Air/water galleries modified for oil cooler delete, Custom block girdle with ARP bolts, 86.5mm omega pistons, Eagle HSP forged rods with ARP bolts, Modified sump with ARP bolts, Lightweight polished knife edged crankshaft, ACL main bearings, ACL big end bearings, Drag spec head with 3 angle valve cut, Ferrea 1mm oversize valves, 1ZZFE shim less bucket conversion, Full port and polish inlet/outlet and chambers, Rogue/cat cams race camshafts 272 dur in/ex 11.4 mm lift, Cat cams adjustable alloy vernier pulleys, Cat cams valve springs and lightweight retainers, Teflon coated Kevlar HKS timing belt, OEM Toyota head gasket, ARP 2000 head studs and bolts, Painted cam cover - fluids used in last 2 years- Toyota long life red coolant & Nanodrive CFS 10w50 fully synthetic oil (Final CR 8:6:1) - £4000
* Magnecor HT leads - £50
* LSD Gearbox - £450
* Shafts - £200
* Os giken r2cd twin plate clutch with custom GTR pressure plates and cover - SOLD
TURBO/EXHAUST
* Billet T04Z triple ceramic ball bearing turbo, Comp cover .70 a/r (inlet) anti surge housing, Precision Exh housing T4 single scroll .58 a/r, Rated to 650hp (had around 3000miles or so at wastegate pressure 0.8bar with very rare use of higher pressure, very good condition) - £800
* Turbo smart 50mm pro gate external wastegate - SOLD
* Stainless screamer pipe - SOLD
* Phoenix power top mount t4 twin scroll stainless exhaust manifold - £500
* 3" turbo back vband downpipe - £100
* Blitz Nur Spec R 80mm exhaust + baffle - SOLD
* GREDDY TD06 20G rated to 450hp - SOLD
* GREDDY gen3 manifold externally gated (needs welding redone as was a half hearted job but no blows) - SOLD
* GREDDY gen2 manifold eternally gated - £350
* Apexi GT exhaust (has couple of dents on box, and flexi needs replaced) - SOLD
FUELING
* In tank walbro 255ltr/hr fuel pump - £50
* Bosch 044 boot mounted secondary fuel pump - SOLD
* Boot mount fuel swirl pot - SOLD
* 1000cc delphi injectors, Rogue custom bored out fuel rail - £350
* Aero motive FPR boot mounted - SOLD
COOLING
* Mishimoto Xline radiator - £200
* 2 x 12" Spal fans for rad - £50
* Rogue (rev6) twin fan engine bay kit - SOLD
* Pwr boot mounted charge cooler 6x10 (rated 650bhp) - SOLD
* Front mount radtec pre rad - £100
* Radtec ChargeCooler Swirl pot in boot - £50
* Turbo smart 50mm blow off valve - £250
* 4" intake with hks filter - £50
* Oil cooler toyosport - £100
* Water meth kit (pump/tank/spray nozzles etc) - £150
ECU/ELECTRONICS
* Apexi avcr blue boost controller - £200
* Apexi AVCR black controller - £250
* Link G1 XLEM ECU with serial link & 2x switches for launch control/flat shift and anti-lag (this ecu still trumps a lot of the newer basic ecus out there) - £400
* Brand new never used AEM wideband gauge and Uego 4.9 lambda sensor (full kit) - SOLD
LIGHTING
* Rogue (rev6) quad headlights (custom stainless housings and hardware) - SOLD
* Rev3+ rear lights, centre panel, reverse lights and loom converted to quad tail/brake lights - SOLD
* Crystal front headlights (straight swap for stock headlights keeping existing mechanism) - £50
* Smoked sidelights - £30
BRAKING/HANDLING/SUSPENSION
* Cusco o-type front strut brace - SOLD
* Cusco o-type rear strut brace - SOLD
* Tein flex coilovers + top mounts (adjustable dampening, height and top mounts) - SOLD
* Powerflex polybushed arms all round, arms all powdercoated gold and fresh ball joints all round (all done around 2years ago and done around 1000miles or less since - SOLD
* Tein front tension rods - SOLD
* TRD front anti roll bar powdercoated gold - SOLD
* Whiteline rear anti roll bar powdercoated gold - £100
* Ultra front chassis under brace (has rust so will need repainted if this bothers you) - £90
* Subframe painted blue to match cusco brace mounts - SOLD
* Grooved and drilled discs + Porterfield R4S race brake pads - SOLD
* Goodrich braided brake lines - £50
* Brake stopper new (non-abs I believe) - SOLD
WHEELS
* Image EV2 17" custom built split rims to SW20 spec 8" + 9" et32 (width, offset & centre bore perfect, so no need for spacers or spigot rings) lips could do with polish - SOLD
* Work VSXX 17" - 8" et35 + 9" et30 - new black studs, powdercoated gold faces, black barrels and polished lips (ready to be built up) - £1200
* Desmond Wise Sports 17" - 8" et30 + 9" et35 (need full refurb) - SOLD
* Volk Rays GTU 16" - 7" et38 + 8" et38 (lips need refurb, centres good, barrels ok) - £500
* OZ Crono 17" - 6.5" et45 + 8" et35 eagle F1 215/40 with plenty tread on front, rear need replaced - SOLD
* NEW Toyo R1R road legal semi slick tyres 245/40/17 - SOLD
* NEW AD08 road legal semi slick tyres 205/40/17 - SOLD
INTERIOR
* Cusco 9 point bolt in dash dodger roll cage plus door bars - SOLD
* Recaro evo4 reclinable bucket seats with custom rails and mounts - SOLD
* Cobra imola 2 frp bucket seats on custom sliding rails and side mounts (unsure on size but it's a perfect fit for 30" waist) - SOLD
* Schroth 6 point anti slip submarine race spec harnesses (driver + passenger) - SOLD
* Full carbon steering wheel - £250
* Personal Monza steering wheel - SOLD
* NRG quick release hub burnt orange - £100
AFTERMARKET BODY STYLING
* Border Carbon bonnet with catches (may have pins also) - SOLD
* Genuine Border carbon bonnet with catches (repaired/half painted white- but sanded back ready for prime and paint) - £300
* Genuine Bomex wing mirrors - SOLD
* Replica Bomex front bumper (needs small repairs) - £50
* Replica Border front bumper (modified sidelights, needs small repair) - SOLD
* Genuine Border front bumper - £450
* Genuine Border front bumper canards - £250
* Carbon headlight covers - SOLD
* Carbon bootlid - SOLD
* F40 style FRP engine lid (NEW Still in gel coat) - SOLD
* Phoenix power style carbon engine cover - SOLD
* Phoenix power style engine cover FRP NEW - SOLD
* Neo side skirts - £250
* Genuine Airwalker side skirts (1 side needs repair) £250
* Veilside side skirts NEW in gel coating - SOLD
* Carbon scoops for side skirt/vent - SOLD
* 1 off Modified Toms rear bumper/diffuser (needs final finishing touches for conversion from uk to jdm plate) - £350
* FRP vented front wings - SOLD
* FRP arch extensions - SOLD
* Border raised inspection panels - SOLD
* Carbon BGW with new custom aluminium brackets (fits between rear lights and spoiler sits around roof height) - £350
STOCK BODY + PANELS
* Shell with zero rust, never been undersealed etc, always dry stored and used only on dry days, windscreen will be left however has a couple of chips, rear screen and rear quarter windows may also be left, will come with all history - £1000
* Rev 5 wing and bootlid - SOLD
* Turbo lid no tray - SOLD
* Wings pair - £50
* o/s door + windows & mechanism - £75
* Bonnet - £50
* Front bumper - £75
* Rear bumper - £75
* Wing mirrors pair - £75
***PREFERENCE FOR STOCK BODY PANELS WILL BE GIVEN TO ANYONE BUYING THE SHELL***
*Prices are collected and some may be negotiable, delivery will be available on some items, however rarer and more fragile items will have to be collected or own courier arranged.
***Parts will be on a first to pay basis, may take deposit to hold for a few days.
I will commence breaking around 3rd/4th week in November.
Im not on here often anymore so better to get me on Facebook under the same name or on the Facebook groups, however I will try to get on as often as possible.
Pictures will be sent on request by Facebook or whatsapp as I don't have a clue how to work the images on here anymore.
500hp SW20 with a host of CARBON & AFTERMARKET parts
Re: 500hp SW20 with a host of CARBON & AFTERMARKET parts
What is the water/meth Kit ? I need one for my car, cheers dude
It's a MSD kit, can send you a pic of it on whatsapp If you send your number over
FORGED BUILD (424hp @ hubs): http://www.imoc.co.uk/forums/viewtopic.php?t=170916
By any chance do you still have your stock ECU? Or something reasonably plug and play?
Sorry I don't, I will need to check if the ecu is wire in or plug in but I believe it may be wire in.
Gullzter wrote:It's a MSD kit, can send you a pic of it on whatsapp If you send your number over
I did a phone reset last weekend but will download whatsapp tomorrow, i'll pm you my number then... Is this kit boost activated ?
bolton wrote:U got shell?
Yes shell is still available
Hi are the coilovers still available?
And do you consider delivery for these?
I have to wait for a bit to be sure as I am moving back to france and have to see if the car can be approved there with coilovers.
Migou wrote:Hi are the coilovers still available?
Yes they are still available and delivery is fine if costs are covered
sure, do you have an idea about how much the delivery would cost for those?
I'll come back to you when I'm sure I can fit those and get my car approved, hopefully they'll still be available
Migou wrote:sure, do you have an idea about how much the delivery would cost for those?
I'd imagine around £20 or so within uk mainland, hard to judge as I don't have them off yet, should be off by next weekend then I can get a postage quote
How much would you be looking for the shell if it hasn't gone already?
Engine lid
Hi I'll take the turbo engine lid postage to Worcester
Cheers Chris
Cheers Chris
Re: Engine lid
chrisy666 wrote:Hi I'll take the turbo engine lid postage to Worcester
Cheers Chris
Engine lid is sold I'm afraid, all other enquiries and pm's replied to
Hi, sorry but I'll have to pospone my purchase of coilovers for now, I have few other expenses in and out of the car, sorry for the time spent.
I might contact you again later, if they are still for sell
I bet all of these have gone by now?
Any budge on the polybush and arms etc? Thinking of doing mine and wondering if i should just get them already done to swap over
