Ok I hope this makes sense.
I just got a set of stock fogs for my tubby to replace the round lights that the chav pervious owner had put in their place. After I managed to get those out I found that he had hacked the stock wiring connectors off the car.
Now my question is this:
Does anybody know where I can get a set of factory 'weather pack' type connectors to repair the factory harness? They are 2 pin units (though the passenger (uk) side light has both a 2 pin and 6 pin and the harness has both 2 and 6 pin connectors.) also does the 6 pin unit have anything to do with the "steering" fog lights?
Mike
Front Fog Wiring harness
Re: Front Fog Wiring harness
Not sure about your pin issues.
Best thing is to try a scrapy and find a tubby.......
If you don't have steering fogs, like UK spec cars (I think I'm right in saying UK cars don't have steering fogs??) again, go to scrappy, or buy new from Mr T - at a premium though.
If UK cars do have steering fogs, then just replace the entire fog wiring loom, to save problems with pinouts etc etc
HTH
HTH
