welshboyo wrote:Hi guys
hope you dont mind me asking
you all.
i was after some advise and you
guys are
in the know
i currently have a rev 2 tubby but i want to go down the rev 3 conversion are these the parts i need
rev 3 ecu
rev 3 injectors
walbro fuel pump
rev 3 map sensor
mat sensor
iat sensor
ignitor
does this sound about right??? and would you have any ideas where i can source these parts from
i have already got the ct20b turbo all rebuilt and a metal head gasket
Hi,
I'm no expert in this by any means, but AFAIK the cylinder head is much different in REV3 so you might need that too.
REV3 engine wiring harness would also be helpful.
I wouldn't go Walbro FP.
Apparently it's loud and doesn't last very long as I read here.
Go with Supra MK4
(290lph) or there is some ATS
(<-or something) pump around which supposed to be very good.
A MAP sensor is very expensive, along with everything else.
You might as well need some hard piping
+ hoses too.
I don't know where to get all this, but you might contact mr-mr2 on ebay.
He was always decent when I needed some parts.
Financially, I think it might be better if you sold your REV2 and try to get a REV3.
Maybe I'm wrong.
Cheers,
Julius
