JLW's ( REV 3 GT spec Turbo, smg Tbar ) YVS Performance Built
Goto page Previous  1, 2, 3 ... , 20, 21, 22  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles
Author Message
Odin_S
PostPosted: Sat Mar 16, 2019 4:29 pm    Post subject: Reply with quote Reply with quote including images
JLW wrote:
Yes seen a few videos, I'm not expecting NA responsiveness. just a nice trade
off, of Acceleration and Power. Looking into getting this started around mid
April.
I have some other Aesthetic plans this year also. But that will depend on the
level I spend finishing the engine lol ! [Rolling Eyes]
Never ending project, i know all too well [Very Happy] Will be following, i'd look into water injection too since we can't get E85 so easily here
Back to top
User is offline
JLW
PostPosted: Wed May 08, 2019 9:34 am    Post subject: Reply with quote Reply with quote including images
So a little update on some things that I wanted to get sorted, I have a
whiteboard in the garage that has "small" and "large" jobs to do on the car.
A couple of which were to paint the space saver as I was sick and tired of
that 24 year old faded yellow. Another was to sand, prepare and treat some
very light surface rust on the slam panel. Along with the final and more tricky
job of creating make shift covers for the suspension top mounts.
The problem with the coilovers is that they allow dirt and water through the top
and gets the Frunk dirty inside. which also leads to slight corrosion on the body
and components over time.
My dad gave me a sheet of thick foam that I measured out the internal
diameter of the hole being 65mm. Then did my best job with a knife to cut it
out and make another incision for the dampening knob. This works quite well
to be honest, but will be a template for a metal cap I will have made.
As you can see there is some light surface rust around the mounting holes
that I will deal with.
I started on the slam panel, by sanding back with A80 and then applying
Kurust.
I have left to dry and will treat the suspension mounts in the same fashion
then will find paint to cover and try and match the OEM grey of the frunk.
or section those parts out with masking tape and use black paint.
Onto the main job, which I actually did prior to the above, but hey.
removed the space saver and got to sanding.
After an hour or so, It was ready to clean off. Used my recently given generator
and air line to clean, then with the help of the misses, masked up the wheel
for its first coat of primer.
I applied 3 coats of primer over a few hour period.
then got to the first coat of the SMG rattle can paint that I bought from Ebay.
To be honest its a really close match so very happy.
However as you can see made the mistake of knocking the can on the wheel
whilst spraying [d'oh!] So left the wheel to dry over night and then sanded the
mark out and recovered with SMG on the latter coats of paint.
Cant see a thing ! [Very Happy] But not content with making one mistake, in haste
sprayed to much lacquer on the second coat and had some pretty nasty runs.
[Applause]
Video: [img]https://i.imgur.com/lnPGoH8.mp4[/img]
So just waited for it to dry and went through the same process I did with the
mark as above. And again very happy with the result. At the end of the day.
This isn't supposed to be impeccable, just to tidy up the Frunk.
But here is the final effort. [Cool]
Whilst I was at it, I used "Black to the future" trim and tyre shine on the
Frunk shroud. And applied a YVS sticker.
I will get a few snaps of it all back together on the weekend.
Back to top
User is offline
JLW
PostPosted: Mon Jun 10, 2019 10:31 am    Post subject: Reply with quote Reply with quote including images
So instead of just putting the car back together, I decided that with the success
of the spare wheel I would paint the strut braces. Along with tackling two
problem area's for corrosion, mostly caused by the strut tower openings.
I started by sanding back the corrosion and then applying KuRust directly on
top of it, then sanded back smooth and started masking up the area's for paint.
I decided to paint the first coats of paint with Hammerite with a brush, this way
could get thick coats down. However I should have just masked up the whole
bay and sprayed straight off as I ended up having to do this anyway !
Brush marks ! wasn't having any of that and didn't expect to get it, but sanded
the paint back to a smooth finish and then began the process of masking up
the Frunk properly for coats with a can.
Few coats down, Slam panel looked great however there must have been some
residual silicone in the strut tower recesses and the paint reacted. So I had to
leave it to dry and sand back the following day and re-apply more coats. [d'oh!]
But after many coats of black and then around 4 coats of lacquer to give it a
nice finish both area's were dry and ready to remove the masking.
The foam inserts I had created actually worked amazing for stopping any paint
getting onto the coilover top mounts, but I had something that I discovered
would work perfectly ready to replace.
65mm wire tidy desk cups [Laughing]
They fit perfectly in the recess and look OEM even having the hole in the exact
position the dampening adjuster sits !!
During the drying time between coats, I was prepping the strut braces. The
OEM Toyota brace was easy as was only painted black. Whereas the TOM's
braces were powder coated. Making them a nightmare to sand back.
The DA on compressor I have definitely helped, even if it only gave me 15
seconds on full blast each time [Evil or Very Mad] [Laughing]
I hung them in the garage and began painting.
Yet stupidly decided to use a filler primer to fill any imperfections after using
standard primer, and had a massive reaction over the TOM's braces FFS.
So whilst I was at work, My mate sanded them back and re-sprayed with
primer for me as I didn't have the time and just wanted to get them back on
the car.
I didn't get any photos of the TOM's braces once I finally finished them,
But did on the OEM toyota one.
Now was time to put them all back together, making sure I torqued back up
as the BGB said.
Well worth all the effort.
Back to top
User is offline
JLW
PostPosted: Tue Jul 30, 2019 9:55 am    Post subject: Reply with quote Reply with quote including images
Now after lots of small updates on the car, time for probably the biggest and
most expensive thing the cars had done to it. Finally time to finish the engine.
After sorting a decent finance option I took the plunge and bought the following
from Paul @ TCB Parts.
. Garrett G25 660 VBand .72ar
. Tubular manifold YVS hand built ( Vband )
. Fuel Injection Clinic 1000cc Injectors
. Top Feed Fuel Rail ( HKS replica ) 11mm
. 4 x Injector Plug & Play Connectors
. Walbro 450lph fuel pump
. Daeschtwerks fuel pressure regulator 1000
. Go Faster Bits FPR gauge
. Tial V44mm external WG
I also ordered a turbo blanket from Exo Racing, that was recommended to me
from a mate.
So all the parts arrived. As you can see I forgot to take a photo of the fuel rail
but its identical, albeit blue. Whilst I was waiting for the parts to arrive myself
and Simon @ YVS discussed the options of how and what we were planning to
do. One being where we intended to map the car.
I had been in contact with Will at Race Dyno Tuning in Doncaster due to his
speciality in mapping this new generation of Turbo, so will be using his hub
based dyno for the new engine modifications.
Next up was getting the car to Simon, This is where things got frankly
ridiculous. Im not going to retype it on here, but if you want to read a ludicrous
story, Its worthwhile !
https://www.facebook.com/512026100/posts/10157215543651101?sfns=mo
So once the car was finally delivered I could rest easy and started receiving
photos of the work.
Fuel pump swapped over and located in the tank.
Beginning of the manifold being created.
Fuel rail and FRP + gauge fitted along with injectors.
Now the cool stuff. Manifold building !
Simon built up a scrap block so that his fabricator had something to work off.
the above photos show this and that the pipes are just tac' welded in place.
Then it began to take shape.
And the last photos I have received to date.
[Very Happy] [Cool] [Applause]
Cant wait to get her to mapping once finished. Oil and Water lines being
created, along with the custom downpipe and waste gate pipe.
The bay will look great, but not really great until I paint that dam cam cover
and inlet manifold + TB !! [Laughing]
Back to top
User is offline
JLW
Admin Please delete
Back to top
User is offline
JLW
PostPosted: Wed Aug 07, 2019 10:56 am    Post subject: Reply with quote Reply with quote including images
Downpipe created and WG fitted, next up will be creating the new pipe running
from the SMIC intake. The downpipe is only tac'ed in place as the manifold was
but will be properly welded once all angles are done.
Back to top
User is offline
Ryan S
PostPosted: Wed Aug 07, 2019 6:35 pm    Post subject: Reply with quote Reply with quote including images
amazing man!!! Looks incredible!
_________________
www.straitupstudios.co.uk
Back to top
User is offline
JLW
PostPosted: Wed Aug 21, 2019 12:48 pm    Post subject: Reply with quote Reply with quote including images
Thanks Pal.
As you can see, I've just received even more photos detailing the work.
Its looking insanely good.
Back to top
User is offline
blogsy
PostPosted: Thu Aug 22, 2019 6:07 am    Post subject: Reply with quote Reply with quote including images
looking really good, can't wait to see it get mapped. [thumleft]
Back to top
User is offline
Dilly
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Thu Aug 29, 2019 12:41 pm    Post subject: Reply with quote Reply with quote including images
Only just found your build thread on here, after getting a couple of pages in I realised it was the MR2 that was on Monky London! Read through it all last night..
Definitely some ups and downs in there!! Good read though.
Lovely MR2, actually really helped me in my choice to finally get one!
I’m watching this build with anticipation now, interesting choice in turbo. Will be cool to see the results of the newer G series turbo. The custom manifold looks Awesome. What sort of spool up / power do you reckon you’ll get?
Back to top
User is offline
JLW
PostPosted: Fri Aug 30, 2019 3:22 pm    Post subject: Reply with quote Reply with quote including images
Hi Bud
Glad you had a good read through, been quite a bit of work putting it all
together, but worth it in the end. Yes but the ups have far outweighed the
downs, Its a great car. And I've definitely learnt lots along the way.
Toby ( Monky London ) and me became mates after the video and will most
definitely be doing another video once this latest round of mods is finished.
TBH when it comes to power and spool etc, I'm just waiting to see really,
I think my biggest limitation will be cooling. So will just have to see how it
pans out.
Keep your eye's on here, not many people on the forums now, which is a
shame. But I'll always upload this page with the cars story. Unless I decide
to one day transfer it onto my own blog style format like "Apex Attack"
but I cant say I have his same interesting content [Laughing]
J.
Back to top
User is offline
shane34
PostPosted: Fri Aug 30, 2019 4:30 pm    Post subject: Reply with quote Reply with quote including images
The info I've seen from a gt4
1bar is @ 3700. Full boost @ 4K 1.8bar 490 bhp.
He has 4k rpm of power band. Vs the old 3076 which was like 2k rpm. The g25 peak power was 7600 rpm
This was the g25 660 .71 ar.
Hoping to start mine this weekend. Maybe we should meet up.for some mapping haha.
Running the bigger ar over yours.
Also the other comments was it's so smooth, no huge kicks like the old set up.
Back to top
User is offline
JLW
PostPosted: Tue Sep 10, 2019 1:15 pm    Post subject: Reply with quote Reply with quote including images
Latest round of photos received from Simon at YVS, including the new
beautifully made intercooler pipe, new air filter + pipe and many new silicone
hose's amongst other stuff. Looking great.
God I need to paint the cam cover + inlet & TB !!!
Back to top
User is offline
JLW
PostPosted: Tue Sep 10, 2019 1:29 pm    Post subject: Reply with quote Reply with quote including images
( Update )
E N G I N E:
. YVS Performance REV 3 Forged Build
. Garrett G25-660 .72AR ( Vband )
. Walhbro 450lph Fuel Pump
. YVS hand built Tubular manifold ( Vband )
. YVS hand built Downpipe with re-routed Screamer
. CP Carillo 86mm Forged Pistons
. ACL Race Main Bearings
. ACL Race Big End Bearings
. ARP Head Stud Conversion
. Helix Uprated Stage 2 4 Paddle Clutch
. Mishimoto Tripple Core Radiator
. Twin SPAL 10" fans
. Link G4 storm standalone ECU
. Phoenix Power side mounted intercooler
. YVS performance hand built intercooler piping
. EXO Racing Turbo Blanket
. Blitz Nur Spec R full exhaust system
. Greddy Type R Adjustable BOV / dump valve
. 8MM Magnecor Ignition Lead Kit
. TRD Sports Iridium Sparkplugs - Grade 7
. K&N high flow air filter
. TOM's radiator cap
. TRD oil cap
. BRD gearbox linkage bushes
. Bosch S4 battery
. Silicone boost pipe hoses
C H A S S I S:
. Meister R zeta R CRD+ coilovers ( 3 way adjustable )
. Whiteline anti-roll bar ( adjustable ) Front & Rear
. SuperPro poly bush kit ( full kit )
. TOM'S Front Strut Brace
. TOM'S Rear Strut Brace
. New drop links & bushings all round
. Eibach Camber Bolts - Front
. Full archwork roll by Arch Enemy
. Supertracker 4 wheel alignment ( Fast road setup )
B R A K E S:
. New Rev 3 Turbo callipers all round
. Porterfield RS4 pads
. MTec dimpled & grooved discs with black coating
. Gulf RF1000 high performance brake fluid
. HEL braided lines all round ( yellow )
. Cusco master cylinder flex stopper
W H E E L S & T Y R E S:
. Front - Rota Torque's 17x8J et35
. Rear - Rota Torque Drifts 17x9J et30 ( 5mm spacers )
. Front - Yokohama AD08r 215/40/17
. Rear - Yokohama AD08r 235/40/17
E X T E R I O R:
. Full re-spray by DPM autobody in OEM "smg"
. Border carbon bonnet
. Genuine Bomex front bumper ( smoothed nose cone )
. TOM's rear bumper
. Carbon scuttle panel
. Carbon reverse light panel
. Aerocatch Plus flush lock kit
. Greddy Gracer side skirts
. Smoothed GT spec electronically retractable mirrors
. TRD wing , with carbon end caps
. Rev 5 clear front light units ( tinted & glossed )
. Raybrig ( style ) Crystal headlight units
. UK spec front indicator delete mouldings
. Full 70% dark window tint by Auto Eclipse
. Team Elemental LED HID kit
. Osram Nightbreaker H3c fog light bulbs
I N T E R I O R :
. OMP corsica 330mm deep dish wheel / yellow stitch
. MoMo boss wheel adapter
. Corbeau Pro series XL in leather with yellow top stitch x2
. Corbeau Side mounts x2
. Rouge Motorsport ground rails
. Corbeau GRH 4 Point Harnesses
. Corbeau inflatable lumbar support ( both seats )
. TRD duration gear knob
. Sickspeed suede / yellow stitch gear surround
. Gloss black dash plastics
. JDM Toyota rescueman 3 security hammer
. JDM OEM toyota footwell flare
. Black rev 1 T-Bar headlining + trims and shades
. UK Rev 5 Leather Door cards
. Modified clock ( blue overlay )
. White 501 LED bulbs in dash
. White LED dome lights
A U D I O:
. Edge 6.5" Front Speakers
. Edge 4" Rear Speakers
. Sony MEX - BT4000U Bluetooth Head unit
S E C U R I T Y:
. Clifford Alarm System 3
S E R V I C E & O I L' S:
. Redline Mt90 gearbox oil
. Fuchs Titan Pro Race R 10w50
. OEM Toyota oil filter
. OEM Toyota fuel filter
Back to top
User is offline
JLW
PostPosted: Tue Oct 08, 2019 3:10 pm    Post subject: Reply with quote Reply with quote including images
And here we are, received the finished photos from Simon: ( albeit minus strut
brace fitted )
So I organised between Simon at YVS and Will at Race Dyno Tuning the best
day to meet and organise the mapping. Which turned out to be Monday the
30th of September.
problem being is that Will needed to start at 9am, and RDT is 30 minutes south
of Doncaster. Me living on the Ashdown forrest in the south meant that its a
near 4 hour trip involving a 5am start, two trains, a tube and a taxi and even
then I wouldn't get there till 9:40am. And because of this Simon very
thankfully drove the car down followed by Liz ( his wife ) to RDT about an hour
south of YVS.
So myself and my stepson who had traveled up with me for the day finally got
there just as they were finishing plugging in the mapping gear.
Hours of mapping later we were starting to build up the power, after sorting
a base map and altering idle and other things etc. It started getting interesting.
VIDEO:
https://i.imgur.com/2gOTNSl.mp4
We started building up boost, but then hit a snag. And potentially a very bad
one. The fuel pressure reg gauge was showing heavy pulsing that could be felt
on the top of the FPR.
VIDEO:
https://i.imgur.com/vCggt9A.mp4
We tried to figure out what could be causing this. One
thought was that maybe the fuel gauge in the car was incorrectly reading,
which has never happened before but it's worth a try. So Liz very kindly
drove a very very stressed Jordan to the closest Shell garage to fill up a 20ltr
can with V Power.
The nightmare of potentially having to have the car shipped back to YVS to
inspect an issue in the fuel tank and then pay another £150 worth of tickets
back home on the train was not doing by mental state well.
However I arrived back to Simon telling me he thought he had cracked it,
and he had. It turned out to be the OEM resistor for the fuel pressure wire had
been damaged during the heavy boost loading sessions, where Will loads up
the dyno to replicate heavy load but then applies heavy boost. Doesn't sound
good and Simons not a big fan of it due to the excessive heat it produces but
each mappers different on how they get their results. And Will gets good
results.
Anyway heart attack averted we cracked on with the mapping, now being
close to 6pm and the nights drawing in and an entire UK storm about to hit
we came to an end ( we thought [Laughing] )
Final power figure attained.
363whp / 425bhp* @ 1.4 bar of boost
* approx based on a half way between 15% and 20% transmission loss.
This was with only 21 degrees centigrade of intake temps which is incredibly
cool, and seeing as heat was always going to be out biggest limiting factor.
shows very good scope for more power.
The goal was always to make a great road car, road useable power not some
dyno queen. Progressive power with a smooth delivery but a fun shove at the
end. Will has definitely done that ! We were at 7pm now and had been mapping
since 10am ! As said there is scope for more power easily, but with the OEM
map sensor only running to 1.5 bar of boost 1.4 was the top. So all thats
needed if I decide to, is buy an aftermarket larger map sensor and up the boost
and map.
All was not done though... Simon advised me to take the car up the road, by
now in the hammering rain and dark to make sure it drove ok, it hit boost cut.
[d'oh!] So I drove back to RDT and Will cam out to confirm and we took it back
rose the boost cut level to 1.7 as it was set at 1.5.
This fixed the issue, and me and Ollie were on our way home. Near on 4 hours
of the worst conditions I've ever driven in, with AD08r's [Confused] yeah it was
stressful. But we got home.
Ive had two days to drive it in good weather since, and it does not disappoint.
the noises it makes are insane, the G25 is like a jet engine behind your ear.
making all manor of turbo sounds.
And most importantly it drives great, with added madness [thumleft]
Next up, painting lots of parts to make the bay look like its had the money I've
spent ! [Laughing]
Back to top
User is offline
SonicSW20
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Tue Oct 08, 2019 6:29 pm    Post subject: Reply with quote Reply with quote including images
Time for a Link 3 or 4 bar MAP sensor and another mapping session! [thumleft]
Back to top
User is offline
JLW
PostPosted: Wed Oct 09, 2019 8:43 am    Post subject: Reply with quote Reply with quote including images
Yeah, next summer once I've had a chance to get used to the 425bhp its
making already, It's by no means slow !!!
Back to top
User is offline
PostPosted: Wed Oct 09, 2019 2:54 pm    Post subject: Reply with quote Reply with quote including images
stunning machine [Applause]
Back to top
User is offline
Ryan S
PostPosted: Wed Oct 09, 2019 4:07 pm    Post subject: Reply with quote Reply with quote including images
Awesome dude!! Mine just made 373 at the wheels today [Smile]
Back to top
User is offline
JLW
PostPosted: Thu Oct 10, 2019 8:37 am    Post subject: Reply with quote Reply with quote including images
Nice bud, what level of boost did you make that with. What turbo & setup etc.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles All times are GMT
Page 21 of 22
Jump to:
