Plugs?
Re: Plugs?
Most likely a BKR5E would do fine - google is your friend though pal a quick search will tell you all you could need to know!
Re: Plugs?
Denso Pk20r8 seem to work just fine.
Re: Plugs?
Use BKR6E They are cheap and do a good job. Its one of the most common plugs used in the MR2 Circle.
