Plugs?
GMLive
Plugs?
Post by GMLive »
Does anyone know which plugs i need for a 93 rev 2 import 3sge?
mr4bx
Premium Member
Re: Plugs?
Post by mr4bx »
Most likely a BKR5E would do fine - google is your friend though pal :thumleft: a quick search will tell you all you could need to know!
ElvisRockVinyl
Re: Plugs?
Post by ElvisRockVinyl »
Denso Pk20r8 seem to work just fine.
Hez
Re: Plugs?
Post by Hez »
Use BKR6E They are cheap and do a good job. Its one of the most common plugs used in the MR2 Circle.
