I've checked the wiring and I don't have 12v feed to the sensor.
Wire colours are:
Black/yellow
Brown
Purple
I know the brown is ground
I believe the black/yellow should be 12v from ECU/ign which leaves purple as feed to dash.
Q.1 Have I got the wires identified correctly.
Q.2.
My bgb is for a 91 so no help as the rev1 has a mechanical Speedo.
any help appreciated.
Chad
Update:
All above is correct, spliced into a switched
Thanks to Paul D for the 93 info.
