[Mk2] [Turbo] Wheel alignment issue
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical
Author Message
bigdave247
1992 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Fri Jun 14, 2019 8:51 am    Post subject: [Mk2] [Turbo] Wheel alignment issue Reply with quote Reply with quote including images
Hi all, i recently had my alignment done on my 92 turbo and now its all over the place, it's like the back end isn't connected to the front end and is constantly trying to swap ends even at low speeds i took it back to national tyres they said it was set properly and that the tyres need to bed in to the new settings can anyone help?
(A bit about the car its on standerd 15" wheels with r888 tyres and mister r coilover susspension and all the bushes are pollys)
I have a print out of the alignment but i dont know how to up load onto here.
Back to top
User is offline
Race Idiot
PostPosted: Fri Jun 14, 2019 10:46 am    Post subject: Reply with quote Reply with quote including images
I'm assuming it feels like crap to drive in the dry because R888's are hardly a good tyre in the wet.
Take a picture of the alignment on yer phone and you can upload it to imgur from the website on phone or just download the imgur app. This will give a link that you can share.
Back to top
User is offline
bigdave247
PostPosted: Fri Jun 14, 2019 12:53 pm    Post subject: Reply with quote Reply with quote including images
http://imgur.com/gallery/dv0kCFz
Back to top
User is offline
Race Idiot
PostPosted: Fri Jun 14, 2019 1:16 pm    Post subject: Reply with quote Reply with quote including images
Wow thats not much camber upfront
Those rear toe values look....off
Here's a known good safe setup
Heres yours
Back to top
User is offline
bigdave247
PostPosted: Fri Jun 14, 2019 1:32 pm    Post subject: Reply with quote Reply with quote including images
Nice one
Back to top
User is offline
bigdave247
PostPosted: Fri Jun 14, 2019 1:44 pm    Post subject: Reply with quote Reply with quote including images
Hi i think my measurements are in mm and yours ate in degrees, if so i think i need more toe in.
Back to top
User is offline
Race Idiot
PostPosted: Fri Jun 14, 2019 4:48 pm    Post subject: Reply with quote Reply with quote including images
Don't think I've ever had an alignment place do it in mm for me haha, so that could be why it looks completely off.
But the camber figures on yours look like there in degrees I dunno 🤔
Back to top
User is offline
abovetherim
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Wed Jun 19, 2019 8:37 pm    Post subject: Reply with quote Reply with quote including images
The caster on the front is off the scale!
Look on alignmycar for a hunters alignment place near you.
Back to top
User is offline
Race Idiot
PostPosted: Mon Jun 24, 2019 10:59 am    Post subject: Reply with quote Reply with quote including images
Well also the fact that caster isn't adjustable unless he's got aftermarket tension rods. Or a rev1 with the different front arm setup
Back to top
User is offline
abovetherim
PostPosted: Tue Jun 25, 2019 6:32 pm    Post subject: Reply with quote Reply with quote including images
The caster will move some when making other adjustments.
Also some front topmounts have eccentric placed hole. Not sure which rev but they could have been fitted oriented wrong.
EDIT
just re read the first post and saw followers so scratch the topmount suggestion
Back to top
User is offline
bigdave247
PostPosted: Wed Jul 10, 2019 10:42 am    Post subject: Reply with quote Reply with quote including images
Hi, all after a lot off Internet searching I realised that I was either toeing in far to much or far to little so I gave it 1 full turn of extra toe in this was a catastrophic mistake the car was crabing in a straight line, so I gave it 2 full turns back out and now the car drives great, I am not sure what the measurements are but I will put it on when I get it professionally checked.
Thanks for everyone's help.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical All times are GMT
Page 1 of 1
Jump to:
