540cc rev 3+ injectors
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
Odin_S
Post by Odin_S »
Removed in perfect working order
£95 Posted
androo007
Re: 540cc rev 3+ injectors
Post by androo007 »
I've got the rail to go with these injectors if needed too for potential buyers that need it....
(Shameless plug, sorry pal :lol: )
Andy
Odin_S
Post by Odin_S »
Hehe thanks Andy,
Are the 440cc rails and 540cc not the same i.e. is it not plug and play?
markstevieandmads
Post by markstevieandmads »
Nope, u have to bore out the earlier fuel rail for the later injectors to fit
androo007
Post by androo007 »
Odin_S wrote:Hehe thanks Andy,
No mate, the Rev 1 & 2 rails are specific for the 440cc injectors, and the Rev 3+ for the 540cc.
kennym
Post by kennym »
I think your all wrong guys,
The injectors will fit in both rails, but the rails will only fit on the heads they were made for.
The reason people bore out rev 2 rails when fitting rev 3 (or bigger) injectors is for increased flow volume, but this is only necessary with higher HP builds.
markstevieandmads
But the rail only holds the injector so the flow volume wouldnt be affected in the rail is bored? Surely its the injector size that deals with the flow volume?
Ive looked into the rev3 ecu swap and they have all bored the fuel rail or used a wolfkatz one.
kennym
Post by kennym »
The rail feeds the injector it doesn't matter how big the injector is if the rail cant feed it, trust me on this one.
you can bore out the rev2 rail to 8mm & feed from both ends, rev2 & 3 injector spscing on the heads are different so the rails are not interchangeable
markstevieandmads
Aah i see
Return to “Mk2”
