Which coolant?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK3 2000-2007
Author Message
HighwayStar
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Fri Aug 03, 2012 5:04 pm    Post subject: Which coolant? Reply with quote Reply with quote including images
Evening all.
The g/f is off for the w/e to Oxfordshire. I've just checked her pressures and fluids etc and her coolant level is just below the 'LOW' level.
All I currently have available is some Carplan Premium Anti freeze and Coolant. It says on the bottle it's ethylene glycol based and incorporates organic acid technology but thought I'd check with you guys that it's a reasonable substitute for the genuine Toyota stuff. Sound OK to me but as it's not my car I just thought I'd check before I pour some in.
R
Back to top
User is offline
Ekona
2004 BMW 6 Series
PostPosted: Fri Aug 03, 2012 5:30 pm    Post subject: Reply with quote Reply with quote including images
Fill it up with some deionised water, then grab a proper bottle of Toyota red after she gets back.
Back to top
User is offline
Driftlimits Performance
IMOC Affiliated Company
PostPosted: Thu Aug 09, 2012 7:12 am    Post subject: Reply with quote Reply with quote including images
Forlife is in it.use that.
_________________
www.DriftlimitsPerformance.co.uk
[email protected]
Back to top
User is offline
RST
Premium Member
2002 Toyota MR2
PostPosted: Sun Nov 11, 2012 3:44 am    Post subject: Reply with quote Reply with quote including images
4Life went out a good while back -they call it Long Life now, it's pretty much no different than red coolant from the likes of Halfords or the factors.
Back to top
User is offline
Willenium
PostPosted: Tue Apr 30, 2013 7:41 pm    Post subject: Reply with quote Reply with quote including images
Sorry to drag an old thread up, didn't think it was worth starting a new one for the same topic.
Having just replaced my radiator I'm looking to fill up with fresh coolant. What are your thoughts on using the below?
http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/antifreeze-and-screenwash/red-antifreeze/?523770511&0&cc5_866
I have heard mixed opinions regarding coolants but I cannot figure out what could be so different between what I have been using and the genuine Toyota item. A brief Google search didn't find me anything about the formulation of Forlife.
Anyone able to offer advice on this at all?
Cheers [thumleft]
Back to top
User is offline
Ekona
2004 BMW 6 Series
PostPosted: Wed May 01, 2013 8:59 am    Post subject: Reply with quote Reply with quote including images
There's two kinds of coolant, red/pink and blue/green. It's probably okay to mix as long as you stick to the correct colour.
For what a bottle of proper Toyota stuff costs, I'd just put that in to be sure.
Back to top
User is offline
BenF
Premium Member
2003 Toyota MR2 Mk3 Roadster Turbo
PostPosted: Sat May 11, 2013 9:57 pm    Post subject: Reply with quote Reply with quote including images
FWIW, I just used Halfords 'advanced' coolant in my Roadster - just because its more convenient to pick up than my local dealer. Its Red as well, just like Forlife ...
Back to top
User is offline
jnoiles
PostPosted: Sat Oct 13, 2018 4:45 pm    Post subject: Reply with quote Reply with quote including images
Genuine question, why? What does Toyota know about keeping ally cold that everyone else doesn't?
Back to top
User is offline
jason256
PostPosted: Wed Oct 17, 2018 6:00 pm    Post subject: Reply with quote Reply with quote including images
I use concentrate millers which is £17 for 5L. I then add deionised water which you can get online in bulk for about £0.25/L. I mix it at 1/3 coolant (good for -20c) as our winters aren't very cold and water is a better coolant for heat capacity and transfer (it just causes corrosion and freezes by itself).
So that's £19.50 for 15L of mixed coolant.
https://www.ebay.co.uk/itm/Millers-Oils-5-Litres-Of-Red-Alpine-Long-Life-Summer-Coolant-Antifreeze/141736042173?epid=1142160505&hash=item2100205ebd:g:648AAOSw9N1VwHD~:rk:2:pf:0
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK3 2000-2007 All times are GMT
Page 1 of 1
Jump to:
