[FINALIZED] MK2 ECUs
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
User avatar
toxo
MK2 ECUs
Post by toxo »
Having a bit of a clearout. I've got:
UK Rev2 3SGE 89661-17370
UK Rev3 3SGE 89661-17500
UK Rev4 3SGE 89661-17550
The rev3 one is the one you need if you are transplanting a late 3SGE from a car with an immobiliser into an older car without an immobiliser.
£40 + £5 delivery each
I also have a UK Rev2 Fan controller module, 89257-17020 if that's of any interest to anyone.
User avatar
toxo
Re: [FINALIZED] MK2 ECUs
Post by toxo »
Any of these can be collected from JAE
User avatar
wilkie senior
Post by wilkie senior »
Hi there
my ECU may be at fault on my rev 5 i have to check it out to see
Would the rev4 be compatable with my UK 1998 rev5?
User avatar
toxo
Post by toxo »
Yes
User avatar
wilkie senior
HI cheers
When i ge the car back for the weekend I will check out the ecu
I will have that one of you if mine appears to be broken /damaged, do you know of any cheack I can do other than cssrefully inspect the components i.e. the caps for bulging / leaking dry joints etc?
User avatar
toxo
Post by toxo »
Nah leaky caps is pretty much it, and when they go bad it's obvious. I can bring it to JAE if you like and you can try it?
User avatar
wilkie senior
hi I will go through the TPS etc
if you could do that that would be worth a shot
mucho appreciated sir
SonicSW20
Post by SonicSW20 »
Are they definitely compatible? The Rev4 and Rev5 EU part numbers are different - http://japan-parts.eu/toyota/eu/1997/mr ... stem#89661
User avatar
toxo
Post by toxo »
Gazza_DJ wrote:Are they definitely compatible? The Rev4 and Rev5 EU part numbers are different - http://japan-parts.eu/toyota/eu/1997/mr ... stem#89661
I'll go with.... reasonably confident lol. If they are different they won't be *very* different. If we struggle I'll pop the tops off and compare pinouts as I'll have both of them in front of me.
There are 2 different ECUs in the ST205 for example which have mildly different part numbers (+30 or so) which are functionally the same and just have very minor code revisions in. But then again the rev3 to rev4 NA ECUs that go from 17500 to 17550 add immobiliser and move the IGF pin. Easy to spot but a bigger change so a bigger jump in part numbers.
SonicSW20
Post by SonicSW20 »
Only one way to find out I suppose! :lol:
User avatar
wilkie senior
ha ha could be interesting!!!
You guys have much more knowledge than I so I bow to that, if my investigation on the TPS yeild nothing looks like a new party game at JAE!!!
User avatar
toxo
Post by toxo »
The immobiliser will be interesting too. I've got detailed wiring diagrams and system documentation for Toyotas of the same era with TVSS but not the MR2. There is a belief that on cars with the later immobiliser (ECU ends 550 or higher) that the ignition key is paired with the ECU. I've seen this in a number of threads on this forum for example. However other TVSS cars have an immobiliser ECU somewhere in the car which is the part paired with the key. The inductive ring in the ignition barrel picks up the transponder in the key and transmits that via a signal amplifier to the immobiliser ECU and if the immobiliser ECU is happy with it it sends a continuous pulse signal to the ECU to say "all is good, continue running". Take the key away, signal stops, engine stops. I know the TVSS MR2s have an immobiliser ECU so I suspect they work exactly the same way and that the ECU is not tied to the ignition key at all.
We shall see :D
SonicSW20
Post by SonicSW20 »
I can confirm that the key is NOT paired with the ECU on a Rev5. I swapped my ECU for another Rev5 one, no issues at all.
In fact, with the Gen3 Turbo swap it is behaving like it is still immobilised... Not sure how to test without either getting a blank key cut or removing the transponder though.
User avatar
toxo
Post by toxo »
Works as I thought then, good
User avatar
wilkie senior
thats one less thing to worry about then, also the central locking on the ofb hasnt worked for some time, when wilki had it
thats one of the jobs to get to that "box" behind the central dash bit & par fresh fobs
User avatar
toxo
Post by toxo »
The central locking and the immobiliser are not linked.
User avatar
wilkie senior
yup realise, just mentioning thats something that needs doing as well
young wilki has left me a lot to put right from his days tutut young uns ehh!!!
User avatar
toxo
Post by toxo »
We will have to see what we can do in a field in Peterborough then :) Won't be the first time haha
SonicSW20
Post by SonicSW20 »
toxo wrote:Works as I thought then, good
Yep, it's the same control unit in all Toyota's of the era (TVSS IIIB?) so it makes sense it's the same as the rest.
User avatar
wilkie senior
toxo wrote:We will have to see what we can do in a field in Peterborough then :) Won't be the first time haha
I might be asking for the TPS setting to be looked at as well, car is in the body shop a bit longer, and i still limited with post op
Anyway see you guys that are going to JAE there, Ill bring my pop up gazeebo in case it rains!!
Return to “Mk2”
