[Mk2] [Turbo] stud info for Manifold - turbo studs??!?
killerferret666
Post by killerferret666 »
I'm after the size and pitch for the 4 studs that the turbo bolts on to. Does anyone know it ?
thanks
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
SonicSW20
Re: [Mk2] [Turbo] stud info for Manifold - turbo studs??!?
Post by SonicSW20 »
Do you just need to replace them? If it's for a Gen3 then I think I have a set of 4 new OEM ones somewhere. Let me know, I'll check when I get home.
IIRC, manifold side is M12*1.25, turbo side is M10*1.25.
killerferret666
Gazza_DJ wrote:Do you just need to replace them? If it's for a Gen3 then I think I have a set of 4 new OEM ones somewhere. Let me know, I'll check when I get home.
No I dont need to replace them (luckily) but the current nuts I have keep coming loose and hence blowing the gaskets. Im making a copper gasket and want to fit self locking nuts on which should solve my issue with them coming undone.
M10 * 1.25 sounds right as thats what i remembered for the turbo side, then have doubted myself.
SonicSW20
Post by SonicSW20 »
What nuts are you using? The OEM ones are a type of locknut, they're 'squished' at the end.
killerferret666
ones that were originally on the car. No squishy bit but do look like an OEM type of nut.
The ones Im looking at are similar. This potentially explains them coming loose then.
SonicSW20
Post by SonicSW20 »
Yeah, they are really a one use item. Installation and removal deforms the nut back to a rounder shape so they don't 'bite' as hard into the stud on further installations.
A new set of OEM nuts should sort it :thumleft:
killerferret666
Gazza_DJ wrote:Yeah, they are really a one use item. Installation and removal deforms the nut back to a rounder shape so they don't 'bite' as hard into the stud on further installations.
cheers for confirming. rung toyota... £7 a nut :lol: :lol: :lol:
So ill pop and get some aero ones from a local place if they have some in or get these ones instead, 5 for the price of a single one.
https://www.ebay.co.uk/itm/Doc-Wob-Supe ... =R40&rt=nc
mr2magic
Post by mr2magic »
If you really want to be certain and don't mind paying a bit more then take a ganders at the stage 8 locking fasteners.
abovetherim
Post by abovetherim »
I got manifold nuts new from Tcb!
toxo
Post by toxo »
Squash the top of the nut in a vice so it's a bit oval shaped.
