3s-GTE ‘putt putt’ sound
3s-GTE âputt puttâ sound
So I notice when at low speeds with low revs in 4th / 5th gear I notice what I can only describe as a âput put' sound from the air filter area.
Is this normal?
Is this normal?
Re: 3s-GTE ‘putt putt’ sound
does it go "chitty chitty bang bang" too?
stock dump valve? farting noise?
craig wrote:stock dump valve? farting noise?
No it's not that, I know that sound.
It's like the engine is coughing.
What air filter?
HKS MUSHROOM type?
HKS MUSHROOM type?
It's a generic stainless steel mesh cone filter.
Is it stuttering/misfiring too? My first thought would be water in the spark plug chambers (if that's what they're called )
Are you sure it's not a leak from the exhaust manifold or turbo gasket? A slightly loose manifold or a small blow on the gasket can cause a slightly whispy put-put sound.
CalMac wrote:Is it stuttering/misfiring too? My first thought would be water in the spark plug chambers (if that's what they're called )
Its not misfiring as it pulls very strongly, but in 4th and 5th gear it doesn't like trying to cruise or pull way at lower revs 40 to 50mph.
I've changed the plugs, and lambda sensor.
shinny wrote:Are you sure it's not a leak from the exhaust manifold or turbo gasket? A slightly loose manifold or a small blow on the gasket can cause a slightly whispy put-put sound.
It's not all the time, just 4th and 5th gear. Sometimes on startup it does a small put put but.
I've just refit the stock exhaust with all new gaskets and VHT silicon sealant.
- wilkie senior
- IMOC Moderator
is on overun or under power?
Regards
Regards
- wilkie senior
- IMOC Moderator
I was going to say O2 sensor but youve done that
Under power, well I say that but more like half throttle if that makes a difference.
Diagnostic fault codes?
- wilkie senior
- IMOC Moderator
i would have thought next step although I havnt for my issues yet DOOOH ha ha
craig wrote:Diagnostic fault codes?
None,
Although it did a bit of kangaroo jumping today going uphill in 5th with the put put noise
- wilkie senior
- IMOC Moderator
Hi
could it be injectors / fuel filter at all?
maybe some injector cleaner additive, (not sure what the general feeling is on that)
One of my company dailys was hesitate as i recall while driving put in some "additive" in my local garage sold me, it worked
Regards
Regards
Injector/ fuel system cleaner been done.
Don't think it's a fuel filter issue.
- wilkie senior
- IMOC Moderator
bu88er running out of ideas!!
Have you checked if any fault codes?
- wilkie senior
- IMOC Moderator
Just an ickkle thought!!!
have you been using supermarket fuel?
Just when mines had it in i never got good economy & it ran roughly
just a thought
just a thought
