JDM Import Rev 2 Turbo - 5SGTE build
rossonza
Re: JDM Import Rev 2 Turbo - Megasquirt install. Anti lag. 2 step.
Post by rossonza »
Well I'm waiting on parts so thought I'd do a recky on the other stuff that needs doing.
Rear wheel lower arches were holed. So I removed the rear bumper....wish I hadn't haha.
Luckily borrowing my mates welder Thursday evening. so plan to take some metal work Friday in the day.
:lol:
rossonza
Post by rossonza »
Ordered my sheet steel. Need to make some cardboard templates then transfer it to metal.
In the mean time my silicone hoses came today. As well as my 3 fuel injector rail standoff washers.
Tomorrows drop fuel tank day I hope.
rossonza
Post by rossonza »
Got the tank dropped today
This bu88er wouldn't undo so I ended up undoing the bottom of the fuel filter and a few bolts along the hard lines
Got the old pump out
New pump made and installed
Inside of the tank looks fine. And that crap wiped off the old pump. Going to drain/swill the tank with fresh fuel.
What an awful job just to change a pump. Worst bit is, I've no clue if it works lol.
Also. Snapped about 3 quarters of the undertray bolts. So going to have to drill them out and re thread them all.
Also used this opportunity to remove the air con hard lines down the whole length of the car.
rossonza
Post by rossonza »
Well. In the drizzle I got my fuel tank back In. It wasn't a nice job by my self. Getting the wiring through the center tunnel. Jesus Christ. I just kept swearing and got it done.
I then got my new alloy radiator and shroud fitted. Electrical connectors need work. But that shouldn't be a problem.
Just waiting on a few parts to get my engine back in.
Feels great to start putting parts back on :thumleft:
Draven
Post by Draven »
Good work lad, still reading. :thumleft:
rossonza
Post by rossonza »
Draven wrote:Good work lad, still reading. :thumleft:
cheers dude! :thumleft:
rossonza
Post by rossonza »
had a nice parcel from mr2 ben :thumleft:
also had a new thermostat but forgot to put it on the carpet for the picture.
planning to fit the new handbrake cables ive got tonight.
hoping to get more done on it tomorrow :thumleft:
rossonza
Post by rossonza »
Well Ive started putting the fuel rail/vac lines/loom/water hoses back on.
Oh how i have forgotten where everything plugs in ](*,)
Wish I'd painted the intake manifold and throttle body now... Oh well it's all coming out again once my other blocks been built up.
rossonza
Post by rossonza »
Whilst I'm waiting on parts in the mail I started work on the future welding. Created some CAD templates:
Hoping to borrow my friends mig this week and get those rear arches sorted.
rossonza
Post by rossonza »
Well my mate popped over and helped me get the gearbox on. Managed to do a bodge to get the flywheel done up. Oh and got the downpipe/turbo back on. Just got to re route the loom and reconnect the water/oil lines.
Just to confirm. The water feed and drain is the same pipe at the bottom of the turbo?
Ross
rossonza
Post by rossonza »
Well she's ready to go back in.
A friend was supposed to be dropping in to help me get it back in the car. Sadly hes gone off radar so engines stuck in my garden ](*,)
Some of the pipework needs a tidy up /clean but I'll save that for next time when the forge build goes in.
I've got builders starting some work on my house early July. So I'm now on a tighter time frame than I'd anticipated.
Here's hoping I can get the engine back in early this week.
platmatt8
Post by platmatt8 »
Looking very good, did you replace the ‘sugar cube' on the gear box?
rossonza
Post by rossonza »
platmatt8 wrote:Looking very good, did you replace the ‘sugar cube' on the gear box?
i havnt? not really sure what it is?
rev2rich
Post by rev2rich »
100% change the hoses from hell while it is out :thumleft:
rossonza
Post by rossonza »
rev2rich wrote:100% change the hoses from hell while it is out :thumleft:
Both changed :-) I think you sold me the hose from hell :D
rev2rich
Post by rev2rich »
rossonza
Post by rossonza »
quick google suggests i can just remove it and turn it 90 degrees. so may try that. failing that looks like its doable back in the bay. :thumleft:
rossonza
Post by rossonza »
My gearbox sugarcube looked relatively new so I've left it alone.
Engines back in though
:mrgreen: :mrgreen: :thumleft:
Just re plumbing everything now. And my god the bottom of the fuse box did not want to clip back together.
Hopefully hear first start in a few days. very excited
rossonza
Post by rossonza »
well i attempted to get it all back together and during so wanted to change out my clutch line for the slave cylinder.
So....attempted to undo the nut that connects the flexi line from the slave cylinder to the cars body and the nuts welded in place with corrosion.
So engine start is on hold :-(
planning to identify the nut size/thread pitch and re-make a new hard line from front to back. Then once the slave cylinders on, ive just got to fit my new ht leads and king lead. oh and a new injector plug. then i should be good to go.
rossonza
Post by rossonza »
Got the clutch line out. my god that was a ball ache. going to remake it from front to back with new ends on.
I also cut out and weld through primered the metal for the rear arch repair:
just waiting on some parts now, so hopefully some progress later on in the week.
