mk2 brake master cylinder upgrade
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Fri Mar 02, 2012 2:20 pm    Post subject: mk2 brake master cylinder upgrade Reply with quote Reply with quote including images
Does it matter if I buy a master cylinder that is off of the ABS model?
Back to top
User is offline
tommundy
Premium Member
1988 Toyota MR2 Mk1.5 Turbo
PostPosted: Fri Mar 02, 2012 7:08 pm    Post subject: Reply with quote Reply with quote including images
You want a non-ABS one afaik. [thumleft]
You'll also need to bend the brake pipes to fit the new cylinder.
Back to top
User is offline
Steve Horrocks
PostPosted: Fri Mar 02, 2012 8:12 pm    Post subject: Reply with quote Reply with quote including images
It's a non ABS one & rev2 onwards as well (15/16's) early mk2 was 7/8's same as a mk1.
Back to top
User is offline
SuperRedMR2
PostPosted: Sat Mar 03, 2012 12:41 pm    Post subject: Reply with quote Reply with quote including images
Thanks Tommy, was unaware of that...Don't really want to be bending pipes in case they snap...May not get this after all.
Back to top
User is offline
Steve Horrocks
PostPosted: Sun Mar 04, 2012 5:13 pm    Post subject: Reply with quote Reply with quote including images
The bending is really just a case of gently manipulating it by hand to be a touch lower. No big deal really.
Back to top
User is offline
Neil_turbo
1987 Toyota MR2 Mk1.5 Turbo
PostPosted: Mon Mar 05, 2012 4:54 pm    Post subject: Reply with quote Reply with quote including images
was barely any bending needed for mine, really no big deal [thumleft]
Back to top
User is offline
aw11rally
1984 Toyota MR2 Mk1a
PostPosted: Mon Mar 05, 2012 5:35 pm    Post subject: Reply with quote Reply with quote including images
Is it worth doing Neil? Noticeable difference? Theoretically you need to press harder but less travel in the pedal, is that what happens in practice though?
Back to top
User is offline
Neil_turbo
PostPosted: Mon Mar 05, 2012 5:41 pm    Post subject: Reply with quote Reply with quote including images
I did this as i have changed my calipers to a rev3 turbo set up, so the standard mk1 MC just didnt shift enough fluid (these have twin piston fronts)
I never really had any issues on standard brakes, so for me i wouldnt change it, if running standard calipers. I guess if just doing this it will decrease feel
I am effectively now running a standard late spec mk2 set up, as even my discs are off a mk2 now!
At the weekend we gutted the bias valve, so will see what happens at the first sprint a week on sunday!
Back to top
User is offline
aw11rally
PostPosted: Mon Mar 05, 2012 7:11 pm    Post subject: Reply with quote Reply with quote including images
I see, so you shouldn't notice any difference as I guess the ratio of MC to piston size is unchanged i.e. As Toyota intended.
We're running huge bremsport 4pots (over 300mm disc) up front and mk1a fronts on the back. The MC is the standard mk1a jobbie, we've got a very long pedal but it requires very little pressure. Occasionally it goes straight to the floor which can be unnerving at high speed. At present I'm not sure whether this is pad knock off after high G corners, the lack of fluid volume moved by the standard MC or the poor vacuum from the ITBs.
I think a mk2 15/16 MC will be the first thing to try.
We currently just drive around the problem with a little left foot braking on the straights at full throttle, this seems to solve the problem. Can cause stained boxers when it catches you out though.
Back to top
User is offline
Lauren
PostPosted: Mon Mar 05, 2012 7:49 pm    Post subject: Reply with quote Reply with quote including images
Doh thought the post was about the servo rather than the master cylinder(!).
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
[email protected]
IMOC Affiliated Company
PostPosted: Mon Mar 05, 2012 7:54 pm    Post subject: Reply with quote Reply with quote including images
Quote:
I would say putting a MK2 master cylinder on is a downgrade
Well you're wrong, it moves more fluid at a slightly lesser pressure, reducing the Mk1's tendancy to lock the fronts, resulting in better stopping power and a reduced overall stopping distance over stock.
Coupled with the twinpot Celica calipers and a gutted bias valve it's one of the best brake upgrades you can do to a Mk1.
The above is proven fact over ten years of doing this.
_________________
Back to top
User is offline
Lauren
PostPosted: Mon Mar 05, 2012 8:23 pm    Post subject: Reply with quote Reply with quote including images
As I said in my previous post I misunderstood and thought the topic was about the servo, not the master cylinder.
Back to top
User is offline
IanParkhouse
PostPosted: Thu Apr 12, 2018 7:03 pm    Post subject: Reply with quote Reply with quote including images
Oh no! I'm slowly losing brake fluid!
I've ordered this:
https://www.ebay.co.uk/itm/Toyota-MR2-MK2-Gen2-Revision2-to-Revision5-Brake-Master-Cylinder-none-abs/273152208869?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908103841%26meid%3D0dd0e678ca634132be54cb6b426fb7ed%26pid%3D100227%26rk%3D1%26rkt%3D11%26sd%3D273152208869%26itm%3D273152208869&_trksid=p2054502.c100227.m3827
Which I think is the appropriate Mk2 version.
Was thinking I'll throw a seal kit in when it comes, does this look like the right kit: https://www.sparepartstore24.co.uk/7799197-abs
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 1 of 1
Jump to:
