[Mk2] [Turbo] Fuel pressure sensor location?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
yokomomr4bx
Premium Member
PostPosted: Mon Feb 12, 2018 6:25 pm    Post subject: [Mk2] [Turbo] Fuel pressure sensor location? Reply with quote Reply with quote including images
Hi guys,
Simple question for those of you out there with fuel pressure gauges, where to did you plumb your sensor in?
Thanks!
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Feb 12, 2018 9:20 pm    Post subject: Reply with quote Reply with quote including images
Aftermarket or stock regulator?
Back to top
User is offline
yokomomr4bx
Premium Member
PostPosted: Mon Feb 12, 2018 9:29 pm    Post subject: Reply with quote Reply with quote including images
Stock regulator
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Feb 12, 2018 10:06 pm    Post subject: Reply with quote Reply with quote including images
Just curious, why do you want to measure stock fuel pressure?
Answer here: http://www.mr2oc.co.uk/forums/41/160495.html
Back to top
User is offline
yokomomr4bx
Premium Member
PostPosted: Mon Feb 12, 2018 10:41 pm    Post subject: Reply with quote Reply with quote including images
Ta, to monitor a very frustrating 'glitch' I'm working through in the thread below:
http://www.imoc.co.uk/forums/viewtopic.php?t=193669
Fuel pressure would otherwise not be high up on my list of gauges to be fitting!
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Tue Feb 20, 2018 6:43 pm    Post subject: Reply with quote Reply with quote including images
between the filter and the rail, not really anywhere else to fit it that see the pressure after the filter.
Back to top
User is offline
yokomomr4bx
Premium Member
PostPosted: Wed Feb 28, 2018 6:33 pm    Post subject: Reply with quote Reply with quote including images
Yes, in terms of general location I was aware it needed to be between the pump and rail! However I was searching for specific location examples, i.e. this point on the fuel rail there is a blank with x thread or at this point in this section of hose the internal diameter is x so i can order an adapter accordingly.
So for anyone who ventures onto this thread in the future I will upload a photo tomorrow of the location I fitted the adaptor T from which to plumb in the pressure sender. But in case I forget to upload a photo...
The flexible pipe between the fuel filter (rail side) banjo and the hard pipe, running underneath the coolant filler neck, is suitable for cutting into and using a fuel pressure sender adaptor with 8mm inlet/outlet ports/barbs. The item I used was a mere 15 from Merlin Motorsport and does the job perfectly.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Fri Mar 09, 2018 3:47 pm    Post subject: Reply with quote Reply with quote including images
just used an inline T at the input end of the rail. Was not running the standard filter-to-rail hose, it was braided with AN fittings.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
