As above.
.and also, if you have aftermarket alloys
/ low-profile tyres, you can get that effect from tramlining, due to the tyre stagger front
/rear.
Check tyre pressures, too.
The UJ in the frunk is open to the elements, especially if you have removed the plastic undertrays.
They can get really sh*tty looking.
.but they often look worse than they actually are: if you don't get steering wheel play when stationary
/ engine off, then it should be ok.
Best way is to get someone to move the steering wheel while you hold the lower column under the UJ: If they're moving the wheel 2+cm left to right and you're not
"feeling it", then there's a problem.
![Wink ;-)](./images/smilies/icon_wink.gif)
