[Mk2] [Generic] SW20 heated windscreen
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Group Buys - MR2 related
Author Message
nathan.z
Premium Member
PostPosted: Tue Jun 28, 2016 9:29 pm    Post subject: Reply with quote Reply with quote including images
So I've lost the installation instructions. I currently keep popping 30amp fuses, wondering what the manufacture recommends? Obv's I'll install a 35amp next but want to double check. [Laughing]
Back to top
User is offline
Marty J
PostPosted: Tue Jun 28, 2016 11:21 pm    Post subject: Reply with quote Reply with quote including images
Nathan, I will get the info for you asap.
Back to top
User is offline
nathan.z
Premium Member
PostPosted: Wed Jun 29, 2016 2:26 pm    Post subject: Reply with quote Reply with quote including images
Thanks Marty. The 35 amp seems to be holding nicely with no fires so far. [thumleft]
Back to top
User is offline
Marty J
PostPosted: Wed Jun 29, 2016 3:22 pm    Post subject: Reply with quote Reply with quote including images
Dual circuit screens so a live and an earth wire either side.
The screen will draw around 14-16 amps per side so fuses to suit are needed ( we recommend 25AMP), this then needs to be wired using good cable through a relay to a switch on the dash.
Some people wire drivers and passenger side separate but most go to the same switch.
Back to top
User is offline
nathan.z
Premium Member
PostPosted: Wed Jun 29, 2016 4:25 pm    Post subject: Reply with quote Reply with quote including images
This explains why the fuse was blowing at 30 amps as both sides are wired to one fuse / relay and switch. (Totalling max 32 amps)
I'll see how the 35 amp fuse holds for now but know that there's margin to move up or rewire dual paths.
Thanks again Marty! [thumleft]
Back to top
User is offline
nathan.z
Premium Member
PostPosted: Fri Dec 16, 2016 2:56 pm    Post subject: Reply with quote Reply with quote including images
Update - The 35 amp fuse held up for a few months but just popped. It also melted the fuse and the fuse holder so looks like my setup needs rewiring into a parallel circuit with 2 fuses splitting the amps in half down the wiring making it safe and less flammable.
[bang]
Back to top
User is offline
thomp1983
PostPosted: Fri Dec 16, 2016 3:41 pm    Post subject: Reply with quote Reply with quote including images
How is the screen performing generally nathan? Is it clearing quickly?
Back to top
User is offline
aussieGT
PostPosted: Sat Dec 17, 2016 9:58 pm    Post subject: Reply with quote Reply with quote including images
[bang]
Clearing quickly? Sounds like it's lighting up the quarter mile by nathans post!
Back to top
User is offline
nathan.z
Premium Member
PostPosted: Tue Jan 03, 2017 8:49 pm    Post subject: Reply with quote Reply with quote including images
aussieGT wrote:
[bang]
When it works it's fantastic, quick and very handy during the winter, I couldn't live without it and I imagine for T-bar owners it'd be a god send. (I remember the days of defrosting the inside of the windscreen on my old T-Bar. I'll post a video as soon as I get a free weekend to fix it.
Back to top
User is offline
monkeyra
1990 Toyota MR2 Mk2 V6
PostPosted: Wed Jan 04, 2017 8:11 am    Post subject: Reply with quote Reply with quote including images
If anyone wants a heated windscreen if I've got a spare one, new and unused, left over from the group buy. Send me a PM if interested.
Back to top
User is offline
nathan.z
Premium Member
PostPosted: Tue Jan 24, 2017 12:51 pm    Post subject: Reply with quote Reply with quote including images
I finally snagged a Sunday to fix the fuse holder. The original fuse holder was only rated for 20amps maximum hence why it melted!
After some deliberation I wired in a mega blade fuse holder rated for 60amps with a 35amp mega blade fuse instead rewiring the circuit for half the amps since it'd mean 2 relays and more work.
Comparison vs new
Overdue video demonstrating the heated windscreen. *I was half asleep this morning so there are a few verbal errors*
https://youtu.be/5gCAqtlhUeI
Need to investigate why one of the heating element strips is not heating up as quickly as the rest of the screen. Maybe there's a loose connection...checked and couldn't find any stone chips on that side.
Back to top
User is offline
thomp1983
PostPosted: Tue Jan 24, 2017 2:55 pm    Post subject: Reply with quote Reply with quote including images
There effective then, I wouldn't personally use it to fully clear the screen as you did in the vid, I'd still scrape the screen the heater is ideal for clearing the condensation that remains so you can get going imo
Back to top
User is offline
filthy
1994 Toyota MR2 Mk2 V6
PostPosted: Fri Nov 10, 2017 11:24 pm    Post subject: Reply with quote Reply with quote including images
Has anybody managed to remove the heater/fan and successfully relied on just the heated windscreen for demisting in wet or damp weather?
Back to top
User is offline
Chumbaside
PostPosted: Thu Nov 16, 2017 3:50 pm    Post subject: Reply with quote Reply with quote including images
Are these screens still available? I'm interested in one for my track car...
Back to top
User is offline
Marty J
PostPosted: Thu Nov 16, 2017 4:36 pm    Post subject: Reply with quote Reply with quote including images
thomp1983 purchased two heated windscreens, maybe he would sell the second one.
Back to top
User is offline
Chumbaside
PostPosted: Thu Nov 16, 2017 5:21 pm    Post subject: Reply with quote Reply with quote including images
Thank you, that's good to know. I'll drop him a PM [thumleft]
Back to top
User is offline
monkeyra
PostPosted: Thu Nov 16, 2017 9:20 pm    Post subject: Reply with quote Reply with quote including images
I've still got mine here, willing to sell.
Back to top
User is offline
thomp1983
PostPosted: Thu Nov 16, 2017 10:17 pm    Post subject: Reply with quote Reply with quote including images
I did indeed buy two but sadly they were both broken during a house move so I never got to use them and I've moved on from my mr2 to a 911
Back to top
User is offline
Kneel
1990 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Fri Feb 09, 2018 10:45 pm    Post subject: Reply with quote Reply with quote including images
PM me if you still have it?
Back to top
User is offline
monkeyra
PostPosted: Sat Feb 10, 2018 7:58 am    Post subject: Reply with quote Reply with quote including images
Pm sent
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Group Buys - MR2 related All times are GMT
Page 7 of 8
Jump to:
