[Mk2] [Turbo] Twin Scroll Turbos
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
blogsy
PostPosted: Wed Nov 08, 2017 5:28 pm    Post subject: [Mk2] [Turbo] Twin Scroll Turbos Reply with quote Reply with quote including images
Can we use our standard exhaust manifolds to run a twin scroll turbo? like a Garrett GTX3067. I realise you would have to make or buy a, Our manifold to a t3 with a divide in it adaptor. But if you had one of them would it work. I keep reading the best way to spool up fast is to have a twin scroll, and although our cars are called twin entry they are actually twin scroll.
Back to top
User is offline
shinny
Premium Member
PostPosted: Thu Nov 09, 2017 2:05 am    Post subject: Reply with quote Reply with quote including images
Why wouldn't it work? The CT26 and CT20b are both twin scroll so, with the right adaptor on the stock manifold, why would there be a problem? Sure the stock manifold isn't equal length so it's slightly sub-optimal, but surely it's still going to be beneficial?
Ebay special adaptor here: https://www.ebay.com/itm/142083473510
No idea how well it fits and it obviously doesn't have space for an external wastegate (if that's something you need)
Back to top
User is offline
blogsy
PostPosted: Thu Nov 09, 2017 12:12 pm    Post subject: Reply with quote Reply with quote including images
Has to be external wastegate, so that's a problem.
Back to top
User is offline
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Thu Nov 09, 2017 12:36 pm    Post subject: Reply with quote Reply with quote including images
https://www.ebay.com/itm/T3-CT26-CT20-Turbo-Flange-Adapter-35-38-Wastegate-MR2/330378863962?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D48754%26meid%3D8aee160547294837b2e0a914b6a8f35c%26pid%3D100623%26rk%3D2%26rkt%3D6%26mehot%3Dag%26sd%3D142083473510&_trksid=p2047675.c100623.m-1
[thumleft]
Back to top
User is offline
blogsy
PostPosted: Fri Nov 10, 2017 7:01 pm    Post subject: Reply with quote Reply with quote including images
Turns out you need to keep the two chambers apart and not let them mix, or you lose the pulse in the exhaust flow. So you need two wastegates. The CT20 has two separate ports behind it's wastegate to prove this point. Not sure I can be ar$ed now [blackeye]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
