[FINALIZED] 2002 Alfa Romeo 147 1.6 Lusso
General items for sale - non MR2 stuff. Caveat Emptor! (Premium Members Only). Topics older than 90 days will be removed.
Essex2Visuvesi
Post by Essex2Visuvesi »
57000 miles with some history, Old MOTs back up the mileage.
Needs a good clean, but a nice little runner.
MOT until June 2017
Issues
This does have a rattle on initial startup which has been diagnosed as the Camshaft Variator. A variator repair kit and full cam belt/water pump service kit is included along with the cam locking tools.
A full set of replacement pads and discs are also included as while they work perfectly well they are getting a little worn.
The drivers seat height adjustment is jammed. this is a common fault on the 147/GT
The door hinges are noisy but good 2nd hand replacements are included
Someone tried to steal the front badge (the didn't succeed as the badge is boiled on) so the bonnet has a screwdriver mark and the badge is bent
There are some quite severe scratches to the drivers door
general parking lumps and bumps
Cruise control is not working. From research on the internet this is most likely just the clutch switch sticking as when I run the diagnostic the clutch switch remains on at all times
If you're looking for a showroom fresh car then this is not the car you're looking for, but if you want a cheap runabout with all the toys then this is worth a look
I've run out of room so this little project needs to go
Car is located in Witham, Essex and is currently not insured and on SORN
Viewing welcome and highly recommended.
Looking for offers around £400
Essex2Visuvesi
Re: [FINALIZED] 2002 Alfa Romeo 147 1.6 Lusso
Forgot this was on here:-
Now sold
Feedback Bot
Post by Feedback Bot »
Return to “General For Sale”
