Want To Change Factory Fit Sony Head Unit
ap78
Post by ap78 »
I want to change the sony console head unit with my own standard size unit.
Can anyone tell me how to go about this, blanking plates...etc?????
Ashy
Re: Want To Change Factory Fit Sony Head Unit
Post by Ashy »
The MR2 uses external amplifiers and sub-woofer amplifiers and so the installation of a new head unit needs a little more thought than for most cars. You need to provide a little more info. What is the year and model of your car. Do you just want to swap the factory unit for a single cd-receiver or multi-cd changer etc. etc. Does your new unit have built in amplifier and/or outputs for external amp. etc. etc. You need to decide exaclty what you want to install and then you can get accurate advice on what you need to do.
ap78
Post by ap78 »
Its a Y-Reg 2001.
Want to install a single cd kenwood mp3 player that has external amp outputs.
User avatar
Driftlimits Performance
IMOC Affiliated Company
Do you know if you car has amps/small sub behind the seat?
ap78
Post by ap78 »
No it doesn't.
Just a factory fit sony system and speakers.
Ian Geary
Post by Ian Geary »
2001? Thats a Mk3 then.
This link might help
http://web.archive.org/web/200501210424 ... stereo.htm
If the link doesn't work (quite likely) go to the General forum and find the recent post about how-to guides from the old IMOC site.
This link is to the guide on how to fit a single DIN stereo to a Mk3
HTH
Ian
GSB
Post by GSB »
Also check the sticky topics in the ICE forum on the Roadster Owners Club... The Mk3 wont take traditional DIN mount head units without an adapter, but you can use ISO mount units (they have screwholes in the sides) and then use a DIN sized cubby hole and a couple of filler pieces to fill the holes that are left over. Halforde sell a wiring adapter to connect to the stock loom.
http://www.mr2roc.org/forum/viewforum.php?f=31
Return to “ICE and Security”
