dellams wrote:Cheers for all the info guys!
Any idea what the light to the right of the battery one is? Its not on the page posted up. It looks like a square with a pipe each end and steam lines coming off the top? Maybe the rad or something?
I cant work it out, my car was fine and then yesterday the battery, the rad? and the engine bay fan lights all came on! Could it be the alternator maybe?
The rad fan at the front still works since I can hear it and when left idling it does not overheat. Ill check the engine bay fan tonight.
Cheers.
Hi, i also have this problem which happens randomly, i have a decat pipe fitted, can anyone shed any light on this?
Regards
Eric
In the end it did turn out to my alternator, it could be your alternator on its way out? Im not sure if they can play up or if they just go completely.
Mine went due to an oil leak from my seals going, you might want to check your alternator to see if it has any oil or any other gunk on it. Mine was coated!
Hope this helps.
dellams wrote:In the end it did turn out to my alternator, it could be your alternator on its way out? Im not sure if they can play up or if they just go completely.
Hope this helps.
Exactly what happened to mine recently, pi$$ed me off to have to replace an already changed 140amp one.
Can we not get a copy of this with the symbols back up? It`s a shame this has gone down its pretty useful, hard to read the relevent bit without the symbol to clarify whats on your dash though.
I had a dash light come on today that I couldn't find on here because the JDM clusters are different to the UK spec so I thought it might help someone else if there were pics of the differences.
JDM MR2 Mk2 Rev1 N/A 3SGE Auto.
I thought I'd post this in case it was useful for others:
I downloaded the original images from somewhere a while ago, and just cleaned them up and added a legend for my own reference.
