If you have read the US boards you'll be aware of "Cap's MAF Mod", where you space the sensor out from the air intake and swap the injectors over for 2ZZ ones. This increases the ignition timing and gives you more torque in the middle of the rev range. There's a place in the states (Corky) who CNC spacers and make a kit with 2 o-rings and 2 longer screws. I have such a kit for sale, which is unused and hasn't been taken out of the packet. This kit + a set of 4 2ZZ (yellow) injectors is all that's required.
I just want back what I paid for it, so £22.50 delivered in the UK.
http://www.spyderchat.com/forums/showth ... -Riser-Mod for more info.
1ZZ MAF Spacer
1ZZ MAF Spacer
Re: 1ZZ MAF Spacer
Just curious, how come you decided not to use this in the end?
Re: 1ZZ MAF Spacer
Am getting rid of the car and the guy wants it as close to stock as possible.
Re: 1ZZ MAF Spacer
1st inline for this please pm sent.
