Distributorless ignition/COP for Power FC & Gen3 ECU (2nd batch)
Forum For IMOC Group Buys
NoddE
Post by NoddE »
Buyers:
scully (MR2 Australia)
randy (MR2OC)
randys friend (MR2OC)
Grajey (IMOC)
stoney1302 (MR2.com)
BlueDragon (MR2OC)
yywhy (MR2OC)
Stahli (MR2.com)
SMT-Racing (MR2OC)
Im doing a second batch of this coil on plug kit for Power FC and Gen3 oem ecus.
It will be 10 kits this time.
Link to old threads:
http://www.imoc.co.uk/forums/viewtopic.php?t=145238
http://www.mr2australia.com/MR2play/tm.aspx?m=31142
Cop kit information:
-Allowes you to get rid of the distributor cap, rotor and ignition wires.
-This kit does not mess up the base ignition timing as long as you dont move around the distributor assy.
-Installation time would be around 3 hours.
-I will have a warranty on my parts that they work.
Videos from the initial testing i did:
YouTube - MrTwo_Idle_PowerFC_COPs.mp4
YouTube - MrTwo_Cold_Start_PowerFC_COPs.mp4
Picture of complete kit (old version):
The price for my kit will be 295 USD incl shipping,
then you need to get coils, igniter, coil harness and spark plugs with removable terminal to complete the kit.
I decided to make it like this because it will be the most cost effective way for you.
Depending on where or how you get these additional parts,
the total price for a sequential ignition system will end up around 260-300 GBP.
It does work with the regular gen3 ECU (or PFC without changing the Dwell/charge time for the coils),
but i recommend that you have a datalogit to change the dwell to the optimum values.
The kit includes these parts:
1pc Box (Sequential module)
1pc Bracket (for Igniter)
1pc Harness (5-wire Extension & 3-wire Signal harness)
1pc Serial cable (for the Box)
1pc Corrugated tube (Cover for the ignition coils harness)
1pc Crimp tube (for the soldering)
1pc 1-pin female plug (for the OEM power wire)
1pc 5-pin male plug (for the Coils harness)
1pc resistor (for the Tacho meter)
1pc M6 bolt (to mount box to fire wall in trunk compartment)
2pcs M5 bolt & lock washer for igniter (igniter version dependent)
3pcs M4 bolt & lock washer for igniter (igniter version dependent)
Parts to get on your own:
4pcs Honda (Denso) CBR600RR Coil (03-09) (Get used ones from Ebay)
Part number: 129700-4510 or J0451
4pcs Denso Spark plug w/ removable terminal (I recommend sparkplugs.co.uk)
Part number: K22PR-U (copper) or IK22 (iridium 0.4mm tip),
for 2.5mm longer plugs you go Q22PR-U or IQ22
1pc Toyota Supra MK4 Igniter (Get used ones from Ebay or driftmotion.com)
Part number: 89621-22020 (old number) or 89621-22030 (new number)
1pc Yamaha R1 Coil Harness (04-09) (Get a used one from Ebay)
NOTE: The Earlier 04-06 harness has a big grey connector while the Later 07-09 harness has a big black connector.
The later black plug harness is long enough to route on the exhaust side of the coil plugs,
the earlier grey plug harness does only fit on the intake side of the coil plug as its shorter.
Anyone interested?
Regards
Jimmy
User avatar
Ryan S
Re: Distributorless ignition/COP for Power FC & Gen3 ECU (2nd batch)
Post by Ryan S »
very interested, got a huge bill to pay shortly after getting my broken studs out though, how soon does this have to be paid??
NoddE
Post by NoddE »
Im thinking about asking for a £70 deposit first and ask for the remainings ones they are ready for shipment.
Will that work for you? :)
User avatar
Ryan S
Post by Ryan S »
NoddE wrote:Im thinking about asking for a £70 deposit first and ask for the remainings ones they are ready for shipment.
yeah that should be fine :thumleft:
NoddE
Post by NoddE »
Edited..
User avatar
Ryan S
Post by Ryan S »
i'm gonna have to hang off for now unfortunately mate, if the group buy is still on the go in a month or so i'll get back on it, just got too much stuff to do to the car that's more important, brakes etc... :(
price is fine though :thumleft:
NoddE
Post by NoddE »
ok.. to bad :)
Anyway, i have 2 interested, so one left for this to happen.
Possible buyers:
randy (MR2OC)
jon
Post by jon »
Hi,
I would be interested in this. I can give you the £70 deposit at the end of the month.
Cheers,
Jon
NoddE
Post by NoddE »
Sounds good, just what we need! :)
Get back to me when you are ready.
/Jimmy
NoddE
Post by NoddE »
Ok this is on.
Ive got payment from 4 persons so im working on 10 more of these kits now.
Buyers so far
randy (MR2OC)
Grajey (IMOC)
NoddE
Post by NoddE »
Another customer added to the list,
Im glad i ordered 16 PCBs while i was on it so i have the option to do another batch of 6 kits :)
NoddE
Post by NoddE »
Kits are ready and the caps are not to far away!
Ill start shipping to the customers who ordered just the kits and the rest will have their stuff as soon as the blanking caps arrive! :)
NoddE
Post by NoddE »
So two more buyers recently.
Only 3 kits left now. :)
NoddE
Post by NoddE »
Only 2 kits left now in case anyones interested :)
I also decided to change the currency to the same all over the world (USD) so people will pay the same no matter where they are from.
dantical
Post by dantical »
does anyone have any info about the dwell time for the 1zz-fe cops ?
I run a power fc, so i Need to know the RPM Dwell times... are they different to the cops used here ?
BTW i baught one of These sets,.. :clap:
NoddE
Post by NoddE »
Dantical, question answered via email :)
I have one more kit left of this batch.
Ive started a new thread where ive done this a bit different and its a limited batch of 5 kits.
Return to “Group Buys - MR2 related”
