The benefits of synthetic oil and why.....
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> IMOC-UK Affiliates -> Opie Oils
Author Message
oilman
IMOC Affiliated Company
PostPosted: Fri Aug 05, 2005 2:03 pm    Post subject: The benefits of synthetic oil and why..... Reply with quote Reply with quote including images
I thought this would be of interest as It's probably the question I get asked the most. Shame the answer isn't simple though!
The basic benefits are as follows:
Extended oil drain periods
Better wear protection and therefore extended engine life
Most synthetics give better MPG
They flow better when cold and are more thermally stable when hot
Esters are surface-active meaning a thin layer of oil on the surfaces at all times
If you want to know the reasons why then please read on but, warning - Long Post!
Stable Basestocks
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or unstable molecules which are prone to thermal and oxidative break down.
Because of their uniform molecular structure, synthetic lubricants operate with less internal and external friction than petroleum oils which have a non-uniform molecular structure.
The result is better heat control, and less heat means less stress to the lubricant.
Higher Percentage of Basestock
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.
This is because multi-viscosity oils need a great deal of pour point depressant and viscosity improvers to operate as a multigrade.
The basestocks actually do most of the lubricating. More basestocks mean a longer oil life.
Additives Used Up More Slowly
Petroleum basestocks are much more prone to oxidation than synthetic oils. Oxidation inhibitors are needed in greater quantities in petroleum oils as they are used up more quickly.
Synthetic oils do oxidize, but at a much slower rate therefore, oxidation inhibiting additives are used up more slowly.
Synthetic oils provide for better ring seal than petroleum oils do. This minimizes blow-by and reduces contamination by combustion by-products. As a result, corrosion inhibiting additives have less work to do and will last much longer in a synthetic oil.
Excellent Heat Tolerance
Synthetics are simply more tolerant to extreme heat than petroleum oils are. When heat builds up within an engine, petroleum oils quickly begin to burn off. They are more volatile. The lighter molecules within petroleum oils turn to gas and what's left are the large molecules that are harder to pump.
Synthetics have far more resistance as they are more thermally stable to begin with and can take higher temperatures for longer periods without losing viscosity.
Heat Reduction
One of the major factors affecting engine life is component wear and/or failure, which is often the result of high temperature operation. The uniformly smooth molecular structure of synthetic oils gives them a much lower coefficient friction (they slip more easily over one another causing less friction) than petroleum oils.
Less friction means less heat and heat is a major contributor to engine component wear and failure, synthetic oils significantly reduce these two detrimental effects.
Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component surface at any given time, thus moving a certain amount of heat into the oil stream and away from the component. This makes synthetic oils far superior heat transfer agents than conventional petroleum oils.
Greater Film Strength
Petroleum motor oils have very low film strength in comparison to synthetics. The film strength of a lubricant refers to it's ability to maintain a film of lubricant between two objects when extreme pressure and heat are applied.
Synthetic oils will typically have a film strength of 5 to 10 times higher than petroleum oils of comparable viscosity.
Even though heavier weight oils typically have higher film strength than lighter weight oils, an sae 30 or 40 synthetic will typically have a higher film strength than an sae 50 or sae 60 petroleum oil.
A lighter grade synthetic can still maintain proper lubricity and reduce the chance of metal to metal contact. This means that you can use oils that provide far better fuel efficiency and cold weather protection without sacrificing engine protection under high temperature, high load conditions. Obviously, this is a big plus, because you can greatly reduce both cold temperature start-up wear and high temperature/high load engine wear using a low viscosity oil.
Engine Deposit Reduction
Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break down. They're better than they used to be, but it still occurs.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as increasing the chance of costly repairs.
Synthetic oils have far superior thermal and oxidative stability and they leave engines virtually varnish, deposit and sludge-free.
Better Cold Temperature Fluidity
Synthetic oils do not contain the paraffins or other waxes which dramatically thicken petroleum oils during cold weather. As a result, they tend to flow much better during cold temperature starts and begin lubricating an engine almost immediately. This leads to significant engine wear reduction, and, therefore, longer engine life.
Improved Fuel Economy
Because of their uniform molecular structure, synthetic oils are tremendous friction reducers. Less friction leads to increased fuel economy and improved engine performance.
This means that more energy released from the combustion process can be transferred directly to the wheels due to the lower friction. Acceleration is more responsive and more powerful, using less fuel in the process.
In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules which are difficult to pump. The engine loses more energy pumping these heavy molecules than if it were pumping lighter ones.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off and when they do, the molecules which are left are of the same size and pumpability is not affected.
Synthetics are better and in many ways, they are basically better by design as they are created by chemists in laboratories for a specific purpose.
Simon
_________________
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
Back to top
User is offline
g14nnh
Guest
PostPosted: Fri Aug 05, 2005 2:16 pm    Post subject: Reply with quote Reply with quote including images
great information. well described. many thanks simon =D>
Back to top
oilman
PostPosted: Fri Aug 05, 2005 2:20 pm    Post subject: Reply with quote Reply with quote including images
You're most welcome [Very Happy]
Simon
Back to top
User is offline
raptor95GTS
Premium Member
PostPosted: Fri Aug 05, 2005 5:09 pm    Post subject: Reply with quote Reply with quote including images
yup indeed, cheers simon for that good info
another sticky methinks or kb article???
Back to top
User is offline
Lauren
PostPosted: Fri Aug 05, 2005 8:43 pm    Post subject: Reply with quote Reply with quote including images
KB Article. Or Sticky. but in the mechanical section, not the general section.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
crazylegs
1985 Toyota MR2 Mk1a
PostPosted: Fri Aug 05, 2005 8:51 pm    Post subject: Reply with quote Reply with quote including images
you should have bunged in a mr2 or three to keep lauren happy [Wink]
does this lady never leave her computer??
Back to top
User is offline
Lauren
PostPosted: Fri Aug 05, 2005 9:47 pm    Post subject: Reply with quote Reply with quote including images
Not at all. its no doubt an informative post going by previous experience. Think if its sticky it should be in mechanical though.
I have no life, so i live behind my PC. [Wink]
Back to top
User is offline
BenF
Premium Member
2003 Toyota MR2 Mk3 Roadster Turbo
PostPosted: Fri Aug 05, 2005 11:43 pm    Post subject: Reply with quote Reply with quote including images
Cheers Simon - After chatting to you at JAE for recommendations for oil for my Roadster Turbo I've just put in the 5w30 Motul 300v fully synthetic you recommended - I'll let you know how I get on with it [Smile]
Highly unscientific first reaction was that the engine sounded a little quieter, but that's probably normal when putting new oil in.
One thing I was wondering about - what do you think the use of engine flushing oils, such as that that Comma supply in 5 litre containers when you are also using Fully synth oils?
Back to top
User is offline
oilman
PostPosted: Sat Aug 06, 2005 12:24 am    Post subject: Reply with quote Reply with quote including images
Don't do it, the Motul will keep your lump as clean as a pin [Dancing]
Simon
Back to top
User is offline
uglee
1997 Toyota MR2 Mk2 V6
PostPosted: Sat Aug 06, 2005 9:21 am    Post subject: Reply with quote Reply with quote including images
What about useing synthetics on an engine that has done around 100,000 miles? I have a rev2 tubby now, useing the same oil as toyota recommended. Would it be beneficail to go fully synthetic at this mileage?
I did have a Mk1 with 140,000 on the clock. changed to fully synthetic and I swear the stuff just dissappeared!! [Very Happy]
Back to top
User is offline
oilman
PostPosted: Sat Aug 06, 2005 6:40 pm    Post subject: Reply with quote Reply with quote including images
There is no problem, so long as the engine is in good shape and is worth it.
I would however use a 5w-40 or 10w-40 synthetic at this mileage.
Simon
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> IMOC-UK Affiliates -> Opie Oils All times are GMT
Page 1 of 1
Jump to:
