Fix T-bar leaks (Silicone and Clingfilm method)
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=46&sid=d78c57864a640ec7241b86304662525e]Knowledge Base - Fix T-bar leaks (Silicone and Clingfilm method)[/url]
Take off the panels and apply the silicone sealant to the underside of the panel
Spread clingfilm over the rubber seals on the car
It'll be dry in a few hours, best leave it overnight if possible.
Worked perfect for me and you only ever see the silicone when the panels are off and upside down.
PS, use lots of cling film, so that if you put on too much silicone it spreads onto the cling film and not your paintwork.
The sealant is just black silicone sealant.
Edit: It's now about 4 years later and no leaks.
