Engine - DIAGNOSTICS
Categories: MR2 Mk3 Articles -> Engine
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=157&sid=c01db6195c940b553ee7464e8551b85b]Knowledge Base - Engine - DIAGNOSTICS[/url]
\PROBLEM SYMPTOMS TABLE\
When the malfunction is not confirmed in the diagnostic trouble code check and the problem still can not be
confirmed in the basic inspection, proceed to this problem symptoms table and troubleshoot according to
the numbered order given below.
Engine does not crank (Does not start)
Suspected Area:-
* Starter
* Starter relay
* Body ECU
No initial combustion (Does not start)
Suspected Area:-
* ECM power source circuit
* Ignition coil with igniter
* Fuel control circuit
* Injector circuit
No complete combustion (Does not start)
Suspected Area:-
* Injector circuit
Engine cranks normally (Difficult to start)
Suspected Area:-
* Starter signal circuit
* Spark plug
* Compression
* Injector circuit
* IAC valve circuit
Cold engine (Difficult to start)
Suspected Area:-
* Injector circuit
* Spark plug
* IAC valve circuit
Hot engine (Difficult to start)
Suspected Area:-
* Injector circuit
* Ignition coil
* Spark plug
* IAC valve circuit
High engine idle speed (Poor idling)
Suspected Area:-
* Back up power source circuit
* IAC valve circuit
Low engine idle speed (Poor idling)
Suspected Area:-
* Injector circuit
* IAC valve circuit
Rough idling (Poor idling)
Suspected Area:-
* IAC valve circuit
* Injector circuit
* Compression
Hunting (Poor idling)
Suspected Area:-
* IAC valve circuit
Hesitation/Poor acceleration (Poor driveability)
Suspected Area:-
* Injector circuit
Muffler explosion, after fire (Poor driveability)
Suspected Area:-
* Ignition coil
* Spark plug
* Injector circuit
Surging (Poor driveability)
Suspected Area:-
* Spark plug
* Injector circuit
Engine stall (Soon after starting)
Suspected Area:-
* IAC valve circuit
Engine stall (After accelerator pedal depressed)
Suspected Area:-
* Injector circuit
* IAC valve circuit
* ECM
Engine stall (After accelerator pedal released)
Suspected Area:-
* ECM
* IAC valve circuit
Engine stall (During A/C operation)
Suspected Area:-
* A/C signal circuit (Compressor circuit)
* ECM
[/u]
