The benefits of synthetic oil and why.....
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=140&sid=459cdbe1aa89a7155f6940c18778412a]Knowledge Base - The benefits of synthetic oil and why.....[/url]
I thought this would be of interest as It\'s probably the question I get asked the most.
The basic benefits are as follows:
Extended oil drain periods
Better wear protection and therefore extended engine life
Most synthetics give better MPG
They flow better when cold and are more thermally stable when hot
Esters are surface-active meaning a thin layer of oil on the surfaces at all times
If you want to know the reasons why then please read on but, warning
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or unstable molecules which are prone to thermal and oxidative break down.
Because of their uniform molecular structure, synthetic lubricants operate with less internal and external friction than petroleum oils which have a non-uniform molecular structure.
The result is better heat control, and less heat means less stress to the lubricant.
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.
This is because multi-viscosity oils need a great deal of pour point depressant and viscosity improvers to operate as a multigrade.
The basestocks actually do most of the lubricating.
Petroleum basestocks are much more prone to oxidation than synthetic oils.
Synthetic oils do oxidize, but at a much slower rate therefore, oxidation inhibiting additives are used up more slowly.
Synthetic oils provide for better ring seal than petroleum oils do.
Synthetics are simply more tolerant to extreme heat than petroleum oils are.
Synthetics have far more resistance as they are more thermally stable to begin with and can take higher temperatures for longer periods without losing viscosity.
One of the major factors affecting engine life is component wear and/or failure, which is often the result of high temperature operation.
Less friction means less heat and heat is a major contributor to engine component wear and failure, synthetic oils significantly reduce these two detrimental effects.
Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component surface at any given time, thus moving a certain amount of heat into the oil stream and away from the component.
Petroleum motor oils have very low film strength in comparison to synthetics.
Synthetic oils will typically have a film strength of 5 to 10 times higher than petroleum oils of comparable viscosity.
Even though heavier weight oils typically have higher film strength than lighter weight oils, an sae 30 or 40 synthetic will typically have a higher film strength than an sae 50 or sae 60 petroleum oil.
A lighter grade synthetic can still maintain proper lubricity and reduce the chance of metal to metal contact.
Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break down.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as increasing the chance of costly repairs.
Synthetic oils have far superior thermal and oxidative stability and they leave engines virtually varnish, deposit and sludge-free.
Synthetic oils do not contain the paraffins or other waxes which dramatically thicken petroleum oils during cold weather.
Because of their uniform molecular structure, synthetic oils are tremendous friction reducers.
This means that more energy released from the combustion process can be transferred directly to the wheels due to the lower friction.
In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules which are difficult to pump.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off and when they do, the molecules which are left are of the same size and pumpability is not affected.
Synthetics are better and in many ways, they are basically better by design as they are created by chemists in laboratories for a specific purpose.
Cheers
Simon
_________________
Contact me: [email protected]
Oil data: http://www.opieoils.co.uk/lubricants.htm
01209 215164
