Changing dissy and rotor arm!!
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=19&sid=cc42bd0c8fc5b7959fcf399dc4c85a08]Knowledge Base - Changing dissy and rotor arm!![/url]
remove 4plugs around dissy cap, using the clips "only", dont go pulling the plugs by the leads!! (mark leads with tape like me!) best to use a flat blade screwdriver to undo the clips!!
unclip the coil as well.
use 10mm rachet for 2 bolts around the cap.
take cap off.
unscrew 2 screws holding cap on, remember what position the old one was in, and replace with new!
put dissy on, do up 2 bolts, put in plugs and coil, away you go!!
