Fuel Octane
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=151&sid=74279221c7540d2c6a02a0d69a05636c]Knowledge Base - Fuel Octane[/url]
Who invented Octane Ratings?
Since 1912 the spark ignition internal combustion engine\'s compression ratio had been constrained by the unwanted \"knock\" that could rapidly destroy engines. \"Knocking\" is a very good description of the sound heard from an engine using fuel of too low octane. The engineers had blamed the \"knock\" on the battery ignition system that was added to cars along with the electric self-starter. The engine developers knew that they could improve power and efficiency if knock could be overcome. Kettering assigned Thomas Midgley, Jr. to the task of finding the exact cause of knock. They used a Dobbie-McInnes manograph to demonstrate that the knock did not arise from preignition, as was commonly supposed, but arose from a violent pressure rise _after_ ignition. The manograph was not suitable for further research, so Midgley and Boyd developed a high-speed camera to see what was happening. They also developed a \"bouncing pin\" indicator that measured the amount of knock. Ricardo had developed an alternative concept of HUCF (Highest Useful Compression Ratio) using a variable-compression engine. His numbers were not absolute, as there were many variables, such as ignition timing, cleanliness, spark plug position, engine temperature. etc.
In 1926 Graham Edgar suggested using two hydrocarbons that could be produced in sufficient purity and quantity. These were \"normal heptane\", that was already obtainable in sufficient purity from the distillation of Jeffrey pine oil, and \" an octane, named 2,4,4-trimethyl pentane \" that he first synthesized. Today we call it \" iso-octane \" or 2,2,4-trimethyl pentane. The octane had a high anti-knock value, and he suggested using the ratio of the two as a reference fuel number. He demonstrated that all the commercially- available gasolines could be bracketed between 60:40 and 40:60 parts by volume heptane:iso-octane.
The reason for using normal heptane and iso-octane was because they both have similar volatility properties, specifically boiling point, thus the varying ratios 0:100 to 100:0 should not exhibit large differences in volatility that could affect the rating test.
Heat of
Melting Point Boiling Point Density Vaporisation
C C g/ml MJ/kg
Normal Heptane -90.7 98.4 0.684 0.365 @ 25C
Iso Octane -107.45 99.3 0.6919 0.308 @ 25C
Having decided on standard reference fuels, a whole range of engines and test conditions appeared, but today the most common are the Research Octane Number (RON), and the Motor Octane Number (MON).
Why do we need Octane Ratings?
To obtain the maximum energy from the gasoline, the compressed fuel/air mixture inside the combustion chamber needs to burn evenly, propagating out from the spark plug until all the fuel is consumed. This would deliver an optimum power stroke. In real life, a series of pre-flame reactions will occur in the unburnt \"end gases\" in the combustion chamber before the flame front arrives. If these reactions form molecules or species that can autoignite before the flame front arrives, knock will occur.
Simply put, the octane rating of the fuel reflects the ability of the unburnt end gases to resist spontaneous autoignition under the engine test conditions used. If autoignition occurs, it results in an extremely rapid pressure rise, as both the desired spark-initiated flame front, and the undesired autoignited end gas flames are expanding. The combined pressure peak arrives slightly ahead of the normal operating pressure peak, leading to a loss of power and eventual overheating. The end gas pressure waves are superimposed on the main pressure wave, leading to a sawtooth pattern of pressure oscillations that create the \"knocking\" sound.
The combination of intense pressure waves and overheating can induce piston failure in a few minutes. Knock and preignition are both favoured by high temperatures, so one may lead to the other. Under high-speed conditions knock can lead to preignition, which then accelerates engine destruction.
What fuel property does the Octane Rating measure?
The fuel property the octane ratings measure is the ability of the unburnt end gases to spontaneously ignite under the specified test conditions. Within the chemical structure of the fuel is the ability to withstand pre-flame conditions without decomposing into species that will autoignite before the flame-front arrives. Different reaction mechanisms, occurring at various stages of the pre-flame compression stroke, are responsible for the undesirable, easily-autoignitable, end gases.
During the oxidation of a hydrocarbon fuel, the hydrogen atoms are removed one at a time from the molecule by reactions with small radical species (such as OH and HO2), and O and H atoms. The strength of carbon-hydrogen bonds depends on what the carbon is connected to. Straight chain HCs such as normal heptane have secondary C-H bonds that are significantly weaker than the primary C-H bonds present in branched chain HCs like iso-octane.
The octane rating of hydrocarbons is determined by the structure of the molecule, with long, straight hydrocarbon chains producing large amounts of easily-autoignitable pre-flame decomposition species, while branched and aromatic hydrocarbons are more resistant. This also explains why the octane ratings of paraffins consistently decrease with carbon number. In real life, the unburnt \"end gases\" ahead of the flame front encounter temperatures up to about 700C due to compression and radiant and conductive heating, and commence a series of pre-flame reactions. These reactions occur at different thermal stages, with the initial stage (below 400C) commencing with the addition of molecular oxygen to alkyl radicals, followed by the internal transfer of hydrogen atoms within the new radical to form an unsaturated, oxygen-containing species. These new species are susceptible to chain branching involving the HO2 radical during the intermediate temperature stage (400-600C), mainly through the production of OH radicals. Above 600C, the most important reaction that produces chain branching is the reaction of one hydrogen atom radical with molecular oxygen to form O and OH radicals.
The addition of additives such as alkyl lead and oxygenates can significantly affect the pre-flame reaction pathways. Antiknock additives work by interfering at different points in the pre-flame reactions, with the oxygenates retarding undesirable low temperature reactions, and the alkyl lead compounds react in the intermediate temperature region to deactivate the major undesirable chain branching sequence.
The antiknock ability is related to the \"autoignition temperature\" of the hydrocarbons. Antiknock ability is _not_ substantially related to:-
1. The energy content of fuel, this should be obvious, as oxygenates have lower energy contents, but high octanes.
2. The flame speed of the conventionally ignited mixture, this should be evident from the similarities of the two reference hydrocarbons. Although flame speed does play a minor part, there are many other factors that are far more important. ( such as compression ratio, stoichiometry, combustion chamber shape, chemical structure of the fuel, presence of antiknock additives, number and position of spark plugs, turbulence etc.) Flame speed does not correlate with octane.
Why are two ratings used to obtain the pump rating?
The correct name for the (RON+MON)/2 formula is the \"antiknock index\", and it remains the most important quality criteria for motorists.
The initial knock measurement methods developed in the 1920s resulted in a diverse range of engine test methods and conditions, many of which have been summarised by Campbell and Boyd. In 1928 the Co-operative Fuel Research Committee formed a sub-committee to develop a uniform knock-testing apparatus and procedure. They settled on a single-cylinder, valve-in-head, water-cooled, variable compression engine of 3.5\"bore and 4.5\" stroke. The knock indicator was the bouncing-pin type. They selected operating conditions for evaluation that most closely match the current Research Method, however correlation trials with road octanes in the early 1930s exhibited such large discrepancies that conditions were changed ( higher engine speed, hot mixture temperature, and defined spark advance profiles ), and a new tentative ASTM Octane rating method was produced. This method is similar to the operating conditions of the current Motor Octane procedure. Over several decades, a large number of alternative octane test methods appeared. These were variations to either the engine design, or the specified operating conditions. During the 1950-1960s attempts were made to internationally standardise and reduce the number of Octane Rating test procedures.
During the late 1940s - mid 1960s, the Research method became the important rating because it more closely represented the octane requirements of the motorist using the fuels/vehicles/roads then available. In the late 1960s German automakers discovered their engines were destroying themselves on long Autobahn runs, even though the Research Octane was within specification. They discovered that either the MON or the Sensitivity ( the numerical difference between the RON and MON numbers ) also had to be specified. Today it is accepted that no one octane rating covers all use. In fact, during 1994, there have been increasing concerns in Europe about the high Sensitivity of some commercially-available unleaded fuels.
The design of the engine and vehicle significantly affect the fuel octane requirement for both RON and MON. In the 1930s, most vehicles would have been sensitive to the Research Octane of the fuel, almost regardless of the Motor Octane, whereas most 1990s engines have a \'severity\" of one, which means the engine is unlikely to knock if a changes of one RON is matched by an equal and opposite change of MON. I should note that the Research method was only formally approved in 1947, but used unofficially from 1942.
What does the Motor Octane rating measure?
The conditions of the Motor method represent severe, sustained high speed, high load driving. For most hydrocarbon fuels, including those with either lead or oxygenates, the motor octane number (MON) will be lower than the research octane number (RON).
Test Engine conditions Motor Octane
Test Method ASTM D2700-92
Engine Cooperative Fuels Research ( CFR )
Engine RPM 900 RPM
Intake air temperature 38 C
Intake air humidity 3.56 - 7.12 g H2O / kg dry air
Intake mixture temperature 149 C
Coolant temperature 100 C
Oil Temperature 57 C
Ignition Advance - variable Varies with compression ratio
( eg 14 - 26 degrees BTDC )
Carburettor Venturi 14.3 mm
What does the Research Octane rating measure?
The Research method settings represent typical mild driving, without consistent heavy loads on the engine.
Test Engine conditions Research Octane
Test Method ASTM D2699-92
Engine Cooperative Fuels Research (CFR)
Engine RPM 600 RPM
Intake air temperature Varies with barometric pressure
( eg 88kPa = 19.4C, 101.6kPa = 52.2C )
Intake mixture temperature Not specified
Ignition Advance - fixed 13 degrees BTDC
Carburettor Venturi Set according to engine altitude
(eg 0-500m=14.3mm, 500-1000m=15.1mm)
Why is the difference called \"sensitivity\"?
RON - MON = Sensitivity. Because the two test methods use different test conditions, especially the intake mixture temperatures and engine speeds, then a fuel that is sensitive to changes in operating conditions will have a larger difference between the two rating methods. Modern fuels typically have sensitivities around 10. The US 87 (RON+MON)/2 unleaded gasoline is recommended to have a 82+ MON, thus preventing very high sensitivity fuels. Recent changes in European gasolines has caused concern, as high sensitivity unleaded fuels have been found that fail to meet the 85 MON requirement of the EN228 European gasoline specification.
What sort of engine is used to rate fuels?
Automotive octane ratings are determined in a special single-cylinder engine with a variable compression ratio (CR 4:1 to 18:1) known as a Cooperative Fuels Research (CFR) engine. The cylinder bore is 82.5mm, the stroke is 114.3mm, giving a displacement of 612 cm3. The piston has four compression rings, and one oil control ring. The intake valve is shrouded. The head and cylinder are one piece, and can be moved up and down to obtain the desired compression ratio. The engines have a special four-bowl carburettor that can adjust individual bowl air-fuel ratios. This facilitates rapid switching between reference fuels and samples. A magnetorestrictive detonation sensor in the combustion chamber measures the rapid changes in combustion chamber pressure caused by knock, and the amplified signal is measured on a \"knockmeter\" with a 0-100 scale. A complete Octane Rating engine system costs about $200,000 with all the services installed. Only one company manufactures these engines, the Waukesha Engine Division of Dresser Industries, Waukesha. WI 53186.
How is the Octane rating determined?
To rate a fuel, the engine is set to an appropriate compression ratio that will produce a knock of about 50 on the knockmeter for the sample when the air-fuel ratio is adjusted on the carburettor bowl to obtain maximum knock. Normal heptane and iso-octane are known as primary reference fuels. Two blends of these are made, one that is one octane number above the expected rating, and another that is one octane number below the expected rating. These are placed in different bowls, and are also rated with each air-fuel ratio being adjusted for maximum knock. The higher octane reference fuel should produce a reading around 30-40, and the lower reference fuel should produce a reading of 60-70. The sample is again tested, and if it does not fit between the reference fuels, further reference fuels are prepared, and the engine readjusted to obtain the required knock. The actual fuel rating is interpolated from the knockmeter readings.
What is the Octane Distribution of the fuel?
The combination of vehicle and engine can result in specific requirements for octane that depend on the fuel. If the octane is distributed differently throughout the boiling range of a fuel, then engines can knock on one brand of 87 (RON+MON)/2, but not on another brand. This \"octane distribution\" is especially important when sudden changes in load occur, such as high load, full throttle, acceleration. The fuel can segregate in the manifold, with the very volatile fraction reaching the combustion chamber first and, if that fraction is deficient in octane, then knock will occur until the less volatile, higher octane fractions arrive.
Some fuel specifications include delta RONs, to ensure octane distribution throughout the fuel boiling range was consistent. Octane distribution was seldom a problem with the alkyl lead compounds, as the tetra methyl lead and tetra ethyl lead octane volatility profiles were well characterised, but it can be a major problem for the new, reformulated, low aromatic gasolines, as MTBE boils at 55C, whereas ethanol boils at 78C. Drivers have discovered that an 87 (RON+MON)/2 from one brand has to be substituted with an 89 (RON+MON)/2 of another, and that is because of the combination of their driving style, engine design, vehicle mass, fuel octane distribution, fuel volatility, and the octane-enhancers used.
What is a \"delta Research Octane number\"?
To obtain an indication of behaviour of a gasoline during any manifold segregation, an octane rating procedure called the Distribution Octane Number was used. The rating engine had a special manifold that allowed the heavier fractions to be separated before they reached the combustion chamber. That method has been replaced by the \"delta\" RON procedure.
The fuel is carefully distilled to obtain a distillate fraction that boils to the specified temperature, which is usually 100C. Both the parent fuel and the distillate fraction are rated on the octane engine using the Research Octane method. The difference between these is the delta RON(100C), usually just called the delta RON. The delta RON ratings are not particularly relevant to engines with injectors, and are not used in the US.
How do other fuel properties affect octane?
Several other properties affect knock. The most significant determinant of octane is the chemical structure of the hydrocarbons and their response to the addition of octane enhancing additives. Other factors include:- Front End Volatility - Paraffins are the major component in gasoline, and the octane number decreases with increasing chain length or ring size, but increases with chain branching. Overall, the effect is a significant reduction in octane if front end volatility is lost, as can happen with improper or long term storage. Fuel economy on short trips can be improved by using a more volatile fuel, at the risk of carburettor icing and increased evaporative emissions. Final Boiling Point.- Decreases in the final boiling point increase fuel octane. Aviation gasolines have much lower final boiling points than automotive gasolines. Note that final boiling points are being reduced because the higher boiling fractions are responsible for disproportionate quantities of pollutants and toxins. Preignition tendency - both knock and preignition can induce each other.
Can higher octane fuels give me more power?
On modern engines with sophisticated engine management systems, the engine can operate efficiently on fuels of a wider range of octane rating, but there remains an optimum octane for the engine under specific driving conditions. Older cars without such systems are more restricted in their choice of fuel, as the engine can not automatically adjust to accommodate lower octane fuel. Because knock is so destructive, owners of older cars must use fuel that will not knock under the most demanding conditions they encounter, and must continue to use that fuel, even if they only occasionally require the octane.
If you are already using the proper octane fuel, you will not obtain more power from higher octane fuels. The engine will be already operating at optimum settings, and a higher octane should have no effect on the management system. Your driveability and fuel economy will remain the same. The higher octane fuel costs more, so you are just throwing money away. If you are already using a fuel with an octane rating slightly below the optimum, then using a higher octane fuel will cause the engine management system to move to the optimum settings, possibly resulting in both increased power and improved fuel economy. You may be able to change octanes between seasons (reduce octane in winter) to obtain the most cost-effective fuel without loss of driveability.
Once you have identified the fuel that keeps the engine at optimum settings, there is no advantage in moving to an even higher octane fuel. The manufacturer\'s recommendation is conservative, so you may be able to carefully reduce the fuel octane. The penalty for getting it badly wrong, and not realising that you have, could be expensive engine damage.
Does low octane fuel increase engine wear?
Not if you are meeting the octane requirement of the engine. If you are not meeting the octane requirement, the engine will rapidly suffer major damage due to knock. You must not use fuels that produce sustained audible knock, as engine damage will occur. If the octane is just sufficient, the engine management system will move settings to a less optimal position, and the only major penalty will be increased costs due to poor fuel economy. Whenever possible, engines should be operated at the optimum position for long-term reliability. Engine wear is mainly related to design, manufacturing, maintenance and lubrication factors. Once the octane and run-on requirements of the engine are satisfied, increased octane will have no beneficial effect on the engine. Run-on is the tendency of an engine to continue running after the ignition has been switched off. The quality of gasoline, and the additive package used, would be more likely to affect the rate of engine wear, rather than the octane rating.
Can I mix different octane fuel grades?
Yes, however attempts to blend in your fuel tank should be carefully planned. You should not allow the tank to become empty, and then add 50% of lower octane, followed by 50% of higher octane. The fuels may not completely mix immediately, especially if there is a density difference. You may get a slug of low octane that causes severe knock. You should refill when your tank is half full. In general the octane response will be linear for most hydrocarbon and oxygenated fuels eg 50:50 of 87 and 91 will give 89.
Attempts to mix leaded high octane to unleaded high octane to obtain higher octane are useless for most commercial gasolines. The lead response of the unleaded fuel does not overcome the dilution effect, thus 50:50 of 96 leaded and 91 unleaded will give 94. Some blends of oxygenated fuels with ordinary gasoline can result in undesirable increases in volatility due to volatile azeotropes, and some oxygenates can have negative lead responses. The octane requirement of some engines is determined by the need to avoid run-on, not to avoid knock.
What happens if I use the wrong octane fuel?
If you use a fuel with an octane rating below the requirement of the engine, the management system may move the engine settings into an area of less efficient combustion, resulting in reduced power and reduced fuel economy. You will be losing both money and driveability. If you use a fuel with an octane rating higher than what the engine can use, you are just wasting money by paying for octane that you can not utilise. The additive packages are matched to the engines using the fuel, for example intake valve deposit control additive concentrations may be increased in the premium octane grade. If your vehicle does not have a knock sensor, then using a fuel with an octane rating significantly below the octane requirement of the engine means that the little men with hammers will gleefully pummel your engine to pieces.
You should initially be guided by the vehicle manufacturer\'s recommendations, however you can experiment, as the variations in vehicle tolerances can mean that Octane Number Requirement for a given vehicle model can range over 6 Octane Numbers. Caution should be used, and remember to compensate if the conditions change, such as carrying more people or driving in different ambient conditions. You can often reduce the octane of the fuel you use in winter because the temperature decrease and possible humidity changes may significantly reduce the octane requirement of the engine.
Use the octane that provides cost-effective driveability and performance, using anything more is waste of money, and anything less could result in an unscheduled, expensive visit to your mechanic.
Can I tune the engine to use another octane fuel?
In general, modern engine management systems will compensate for fuel octane, and once you have satisfied the optimum octane requirement, you are at the optimum overall performance area of the engine map. Tuning changes to obtain more power will probably adversely affect both fuel economy and emissions. Unless you have access to good diagnostic equipment that can ensure regulatory limits are complied with, it is likely that adjustments may be regarded as illegal tampering by your local regulation enforcers. If you are skilled, you will be able to legally wring slightly more performance from your engine by using a dynamometer in conjunction with engine and exhaust gas analyzers and a well-designed, retrofitted, performance engine management chip.
How can I increase the fuel octane?
Not simply, you can purchase additives, however these are not cost-effective and a survey in 1989 showed the cost of increasing the octane rating of one US gallon by one unit ranged from 10 cents (methanol), 50 cents (MMT), $1.00 (TEL), to $3.25 (xylenes) [108]. Refer to section 6.20 for a discussion on naphthalene (mothballs). It is preferable to purchase a higher octane fuel such as racing fuel, aviation gasolines, or methanol. Sadly, the price of chemical grade methanol has almost doubled during 1994. If you plan to use alcohol blends, ensure your fuel handling system is compatible, and that you only use dry gasoline by filling up early in the morning when the storage tanks are cool. Also ensure that the service station storage tank has not been refilled recently. Retailers are supposed to wait several hours before bringing a refilled tank online, to allow suspended undissolved water to settle out, but they do not always wait the full period.
Are aviation gasoline octane numbers comparable?
Aviation gasolines were all highly leaded and graded using two numbers, with common grades being 80/87, 100/130, and 115/145. The first number is the Aviation rating (aka Lean Mixture rating), and the second number is the Supercharge rating ( aka Rich Mixture rating ). In the 1970s a new grade, 100LL (low lead = 0.53mlTEL/L instead of 1.06mlTEL/L) was introduced to replace the 80/87 and 100/130. Soon after the introduction, there was a spate of plug fouling, and high cylinder head temperatures resulting in cracked cylinder heads. The old 80/87 grade was reintroduced on a limited scale. The Aviation Rating is determined using the automotive Motor Octane test procedure, and then converted to an Aviation Number using a table in the method. Aviation Numbers below 100 are Octane numbers, while numbers above 100 are Performance numbers. There is usually only 1 - 2 Octane units different to the Motor value up to 100, but Performance numbers varies significantly above that eg 110 MON = 128 Performance number.
The second Avgas number is the Rich Mixture method Performance Number (PN - they are not commonly called octane numbers when they are above 100), and is determined on a supercharged version of the CFR engine which has a fixed compression ratio. The method determines the dependence of the highest permissible power (in terms of indicated mean effective pressure) on mixture strength and boost for a specific light knocking setting. The Performance Number indicates the maximum knock-free power obtainable from a fuel compared to iso-octane = 100. Thus, a PN = 150 indicates that an engine designed to utilise the fuel can obtain 150% of the knock-limited power of iso-octane at the same mixture ratio. This is an arbitrary scale based on iso-octane + varying amounts of TEL, derived from a survey of engines performed decades ago. Aviation gasoline PNs are rated using variations of mixture strength to obtain the maximum knock-limited power in a supercharged engine. This can be extended to provide mixture response curves which define the maximum boost (rich - about 11:1 stoichiometry) and minimum boost (weak about 16:1 stoichiometry) before knock.
The 115/145 grade is being phased out, but even the 100LL has more octane than any automotive gasoline.
Can mothballs increase octane?
The legend of mothballs as an octane enhancer arose well before WWII when naphthalene was used as the active ingredient. Today, the majority of mothballs use para-dichlorobenzene in place of naphthalene, so choose carefully if you wish to experiment . There have been some concerns about the toxicity of para-dichlorobenzene, and naphthalene mothballs have again become popular. In the 1920s, typical gasoline octane ratings were 40-60, and during the 1930s and 40s, the ratings increased by approximately 20 units as alkyl leads and improved refining processes became widespread.
Naphthalene has a blending motor octane number of 90, so the addition of a significant amount of mothballs could increase the octane, and they were soluble in gasoline. The amount usually required to appreciably increase the octane also had some adverse effects. The most obvious was due to the high melting point (80C), when the fuel evaporated the naphthalene would precipitate out, blocking jets and filters. With modern gasolines, naphthalene is more likely to reduce the octane rating, and the amount required for low octane fuels will also create operational and emissions problems.
What is the effect of Compression ratio?
Most people know that an increase in Compression Ratio will require an increase in fuel octane for the same engine design. Increasing the compression ratio increases the theoretical thermodynamic efficiency of an engine according to the standard equation
Efficiency = 1 - (1/compression ratio)^gamma-1
where gamma = ratio of specific heats at constant pressure and constant volume of the working fluid (for most purposes air is the working fluid, and is treated as an ideal gas). There are indications that thermal efficiency reaches a maximum at a compression ratio of about 17:1.
The efficiency gains are best when the engine is at incipient knock, that\'s why knock sensors (actually vibration sensors) are used. Low compression ratio engines are less efficient because they can not deliver as much of the ideal combustion power to the flywheel. For a typical carburetted engine, without engine management:-
Compression Ratio Octane Number Requirement Brake Thermal Efficiency
(Full Throttle)
5:1 72 -
6:1 81 25%
7:1 87 28%
8:1 92 32%
9:1 96 32%
10:1 100 33%
11:1 104 34%
12:1 108 34%
Modern engines have improved significantly on this, and the changing fuel specifications and engine design should see more improvements, but significant gains may have to await improved engine materials and fuels.
What is the effect of changing the air/fuel ratio?
Traditionally, the greatest tendency to knock was near 13.5:1 air/fuel ratio, but was very engine specific. Modern engines, with engine management systems, now have their maximum octane requirement near to 14.5:1. For a given engine using gasoline, the relationship between thermal efficiency, air/fuel ratio, and power is complex. Stoichiometric combustion (Air/Fuel Ratio = 14.7:1 for a typical non-oxygenated gasoline) is neither maximum power - which occurs around A/F 12-13:1 (Rich), nor maximum thermal efficiency - which occurs around A/F 16-18:1 (Lean). The air-fuel ratio is controlled at part throttle by a closed loop system using the oxygen sensor in the exhaust. Conventionally, enrichment for maximum power air/fuel ratio is used during full throttle operation to reduce knocking while providing better driveability. If the mixture is weakened, the flame speed is reduced, consequently less heat is converted to mechanical energy, leaving heat in the cylinder walls and head, potentially inducing knock. It is possible to weaken the mixture sufficiently that the flame is still present when the inlet valve opens again, resulting in backfiring.
What is the effect of changing the ignition timing
The tendency to knock increases as spark advance is increased, eg 2 degrees BTDC requires 91 octane, whereas 14 degrees BTDC requires 96 octane. If you advance the spark, the flame front starts earlier, and the end gases start forming earlier in the cycle, providing more time for the autoigniting species to form before the piston reaches the optimum position for power delivery, as determined by the normal flame front propagation. It becomes a race between the flame front and decomposition of the increasingly-squashed end gases. High octane fuels produce end gases that take longer to autoignite, so the good flame front reaches and consumes them properly. The ignition advance map is partly determined by the fuel the engine is intended to use. The timing of the spark is advanced sufficiently to ensure that the fuel/air mixture burns in such a way that maximum pressure of the burning charge is about 15-20 degree after TDC. Knock will occur before this point, usually in the late compression/early power stroke period. The engine management system uses ignition timing as one of the major variables that is adjusted if knock is detected. If very low octane fuels are used (several octane numbers below the vehicle\'s requirement at optimal settings), both performance and fuel economy will decrease.
The actual Octane Number Requirement depends on the engine design, but for some 1978 vehicles using standard fuels, the following (R+M)/2 Octane Requirements were measured. \"Standard\" is the recommended ignition timing for the engine, probably a few degrees before Top Dead Centre.
Basic Ignition Timing
Vehicle Retarded 5 degrees Standard Advanced 5 degrees
A 88 91 93
B 86 90.5 94.5
C 85.5 88 90
D 84 87.5 91
E 82.5 87 90
The actual ignition timing to achieve the maximum pressure from normal combustion of gasoline will depend mainly on the speed of the engine and the flame propagation rates in the engine. Knock increases the rate of the pressure rise, thus superimposing additional pressure on the normal combustion pressure rise. The knock actually rapidly resonates around the chamber, creating a series of abnormal sharp spikes on the pressure diagram. The normal flame speed is fairly consistent for most gasoline HCs, regardless of octane rating, but the flame speed is affected by stoichiometry. Note that the flame speeds in this FAQ are not the actual engine flame speeds. A 12:1 CR gasoline engine at 1500 rpm would have a flame speed of about 16.5 m/s, and a similar hydrogen engine yields 48.3 m/s, but such engine flame speeds are also very dependent on stoichiometry.
What is the effect of engine management systems?
Engine management systems are now an important part of the strategy to reduce automotive pollution. The good news for the consumer is their ability to maintain the efficiency of gasoline combustion, thus improving fuel economy. The bad news is their tendency to hinder tuning for power. A very basic modern engine system could monitor and control:- mass air flow, fuel flow, ignition timing, exhaust oxygen ( lambda oxygen sensor ), knock (vibration sensor ), EGR, exhaust gas temperature, coolant temperature, and intake air temperature. The knock sensor can be either a nonresonant type installed in the engine block and capable of measuring a wide range of knock vibrations (5-15 kHz) with minimal change in frequency, or a resonant type that has excellent signal-to-noise ratio between 1000 and 5000 rpm.
A modern engine management system can compensate for altitude, ambient air temperature, and fuel octane. The management system will also control cold start settings, and other operational parameters. There is a new requirement that the engine management system also contain an on-board diagnostic function that warns of malfunctions such as engine misfire, exhaust catalyst failure, and evaporative emissions failure. The use of fuels with alcohols such as methanol can confuse the engine management system as they generate more hydrogen which can fool the oxygen sensor.
The use of fuel of too low octane can actually result in both a loss of fuel economy and power, as the management system may have to move the engine settings to a less efficient part of the performance map. The system retards the ignition timing until only trace knock is detected, as engine damage from knock is of more consequence than power and fuel economy.
What is the effect of temperature and load?
Increasing the engine temperature, particularly the air/fuel charge temperature, increases the tendency to knock. The Sensitivity of a fuel can indicate how it is affected by charge temperature variations. Increasing load increases both the engine temperature, and the end-gas pressure, thus the likelihood of knock increases as load increases.
What is the effect of engine speed?
Faster engine speed means there is less time for the pre-flame reactions in the end gases to occur, thus reducing the tendency to knock. On engines with management systems, the ignition timing may be advanced with engine speed and load, to obtain optimum efficiency at incipient knock. In such cases, both high and low engines speeds may be critical.
What is the effect of engine deposits?
A new engine may only require a fuel of 6-9 octane numbers lower than the same engine after 25,000 km. This Octane Requirement Increase (ORI) is due to the formation of a mixture of organic and inorganic deposits resulting from both the fuel and the lubricant. They reach an equilibrium amount because of flaking, however dramatic changes in driving styles can also result in dramatic changes of the equilibrium position. When the engine starts to burn more oil, the octane requirement can increase again. ORIs up to 12 are not uncommon, depending on driving style. The deposits produce the ORI by several mechanisms:-
- they reduce the combustion chamber volume, effectively increasing the compression ratio. - they also reduce thermal conductivity, thus increasing the combustion chamber temperatures. - they catalyse undesirable pre-flame reactions that produce end gases with low autoignition temperatures.
What is the Road Octane requirement of an vehicle?
The actual octane requirements of a vehicle is called the Octane Number Requirement (ONR), and is determined by using standard octane fuels that can be blends of iso-octane and normal heptane, or commercial gasolines. The vehicle is tested under a wide range of conditions and loads, using different octane fuels until trace knock is detected. The conditions that require maximum octane are not consistent, but often are full-throttle acceleration from low starting speeds using the highest gear available. They can even be at constant speed conditions. Engine management systems that adjust the octane requirement may also reduce the power output on low octane fuel, resulting in increased fuel consumption. The maximum ONR is of most interest, as that usually defines the recommended fuel. The octane rating engines do not reflect actual conditions in a vehicle, consequently there are standard procedures for evaluating the performance of the gasoline in an engine. The most common are:-
1. The Modified Uniontown Procedure. Full throttle accelerations are made from low speed using primary reference fuels. The ignition timing is adjusted until trace knock is detected at some stage. Several reference fuels are used, and a Road Octane Number v Basic Ignition timing graph is obtained. The fuel sample is tested, and the ignition timing setting is read from the graph to provide the Road Octane Number. This is a rapid procedure but provides minimal information.
2. The Modified Borderline Knock Procedure. The automatic spark advance is disabled, and a manual adjustment facility added. Accelerations are performed as in the Modified Uniontown Procedure, however trace knock is maintained throughout the run. A map of ignition advance v engine speed is made for several reference fuels and the sample fuels. This procedure can show the variation of road octane with engine speed.
What is the effect of air temperature?
An increase in ambient air temperature of 5.6C increases the octane requirement of an engine by 0.44 - 0.54 MON. When the combined effects of air temperature and humidity are considered, it is often possible to use one octane grade in summer, and use a lower octane rating in winter. The Motor octane rating has a higher charge temperature, and increasing charge temperature increases the tendency to knock, so fuels with low Sensitivity (the difference between RON and MON numbers) are less affected by air temperature.
What is the effect of altitude?
The effect of increasing altitude may be nonlinear, with one study reporting a decrease of the octane requirement of 1.4 RON/300m from sea level to 1800m and 2.5 RON/300m from 1800m to 3600m. Other studies report the octane number requirement decreased by 1.0 - 1.9 RON/300m without specifying altitude. Modern engine management systems can accommodate this adjustment, and in some recent studies, the octane number requirement was 0.2 - 0.5 Antiknock Index/300m. The reduction on older engines was due to:-
- reduced air density provides lower combustion temperature and pressure.
- fuel is metered according to air volume, consequently as density decreases the stoichiometry moves to rich, with a lower octane number requirement.
- manifold vacuum controlled spark advance, and reduced manifold vacuum results in less spark advance.
What is the effect of humidity?
An increase of absolute humidity of 1.0 g water/ kg of dry air lowers the octane requirement of an engine by 0.25 - 0.32 MON.
What does water injection achieve?
Water injection was used in WWII aviation engine to provide a large increase in available power for very short periods. The injection of water does decrease the dew point of the exhaust gases. This has potential corrosion problems. The very high specific heat and heat of vaporisation of water means that the combustion temperature will decrease. It has been shown that a 10% water addition to methanol reduces the power and efficiency by about 3%, and doubles the unburnt fuel emissions, but does reduce NOx by 25%.
A decrease in combustion temperature will reduce the theoretical maximum possible efficiency of an otto cycle engine that is operating correctly, but may improve efficiency in engines that are experiencing abnormal combustion on existing fuels.
Some aviation SI engines still use boost fluids. The water/methanol mixtures are used to provide increased power for short periods, up to 40% more - assuming adequate mechanical strength of the engine. The 40/60 or 45/55 water/methanol mixtures are used as boost fluids for aviation engines because water would freeze. Methanol is just \"preburnt\" methane, consequently it only has about half the energy content of gasoline, but it does have a higher heat of vaporisation, which has a significant cooling effect on the charge. Water/methanol blends are more cost-effective than gasoline for combustion cooling. The high Sensitivity of alcohol fuels has to be considered in the engine design and settings.
Boost fluids are used because they are far more economical than using the fuel. When a supercharged engine has to be operated at high boost, the mixture has to be enriched to keep the engine operating without knock. The extra fuel cools the cylinder walls and the charge, thus delaying the onset of knock which would otherwise occur at the associated higher temperatures.
The overall effect of boost fluid injection is to permit a considerable increase in knock-free engine power for the same combustion chamber temperature. The power increase is obtained from the higher allowable boost. In practice, the fuel mixture is usually weakened when using boost fluid injection, and the ratio of the two fuel fluids is approximately 100 parts of avgas to 25 parts of boost fluid. With that ratio, the resulting performance corresponds to an effective uprating of the fuel of about 25%, irrespective of its original value. Trying to increase power boosting above 40% is difficult, as the engine can drown because of excessive liquid.
Note that for water injection to provide useful power gains, the engine management and fuel systems must be able to monitor the knock and adjust both stoichiometry and ignition to obtain significant benefits. Aviation engines are designed to accommodate water injection, most automobile engines are not. Returns on investment are usually harder to achieve on engines that do not normal extend their performance envelope into those regions. Water injection has been used by some engine manufacturers - usually as an expedient way to maintain acceptable power after regulatory emissions baggage was added to the engine, but usually the manufacturer quickly produces a modified engine that does not require water injection.
